Old 07-09-2008, 11:15 PM   #1
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Exclamation Ip addresses ?????
Hi everyone, Does anyone know of a good freeware IP adress hider/masker, or something that shows my IP address as another IP address. Im looking for a freeware program if possible . cheers . Thanks.
EDIT: for Vista ;).
:eclipsee_
Old 08-09-2008, 08:42 AM   #2
sgt_doofey
sgt_doofey's Avatar
Ummm. Why? You looking at doing something illegal?
One solution would be to use a proxy server.
Cheers,
Sam.
sgt_doofey is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2008, 11:23 AM   #3
XR6-VCT-2000
Fantastic Plastic
No no , not at all. It's just a game myself and my missus play online. We both used to be able to play it in different rooms on different pc's at the same time, but recently for some reason it won't allow 2 players from the same IP to be online at one time anymore : .
I don't realy want to have to run a server just to mask my IP, there used to be heaps of free small programs out for 98', ME , and XP a few years back - I still can't find one for vista or that will work with vista though.
:eclipsee_
Old 08-09-2008, 01:47 PM   #4
sgt_doofey
sgt_doofey's Avatar
Running something locally on your PC will probably mask the IP address of your PC, but not the one of the WAN address that your broadband (or dial-up) uses.
Set one computer to use a proxy as the default gateway and that might help. There are plenty of free on-line ones that you can use.
Cheers,
Sam.
Old 08-09-2008, 05:55 PM   #5
Rodp
Regular Schmuck
Rodp's Avatar
I'd have to concur with Doofey. Internal to your network your last hop before the internet is likely a router, every packet you send out, regardless of how many machines you have in your internal network will have the same WWN and IP. Any app you install to try and mask your IP will only mask it within your subnet.
I used to run a virtual machine that I used as a proxy that, if I routed through, would make me totally anonymous (which isn't what you're actually going for). It apparently used a matrix of proxies that would spoof your IP but at the (massive) cost of performance. It would likely make gaming impossible.
An external proxy would likely achieve what you're looking for. Never used a public one but Google is your friend.
Rodp is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2008, 07:40 PM   #6
XR6-VCT-2000
Fantastic Plastic
Thanks fellas , that has helped , cheers ;) .
:eclipsee_
Old 08-09-2008, 08:07 PM   #7
flappist
Or ask your ISP to route several addresses to your router and SNAT each internal host individually.
Telstra will do it with BB/TID as will many of the others but probably not on the unlimited $19.95 povvo plans.
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2008, 09:03 PM   #8
V3RSAC3
... Fear it!
V3RSAC3's Avatar
polysolve.com
Originally Posted by Mr Hardware
Just remember gents, anyone can follow fashion, but it takes someone with real class and finesse to have Style.
Chrysler 300C Sedan
SY Territory Ghia
V3RSAC3 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
