Will an 84 telstar engine bolt straight into an 86 telstar body????? they both manual...
Over Thinker
83-87 were all fitted with a 2 ltr motor and have the same chassis shape
the manual gearboxes didnt change externally as a suggestion I would check the rear main seal / timing belt the water pump/welsh plugs before fitting into the car go for it you are going backwards so the modification does not need engineering
My car goes Brumm Brumm |
awesome cheers
