27-12-2007, 08:14 PM | #1 | ||
XA GT
1) Is it legal in victoria to put the mk2 2L in the mk1 escort?
2) Does the auto gearbox off the mk1 1300 bolt up to the mk2 2L? 3) Can you still get the window seals for the mk1 coupes, if so, where are the best places to buy them? Thanks. |
27-12-2007, 09:23 PM | #2 | ||
From memory YES the 1300 mk1 auto box will bolt up to your 2L pinto. bell housing will meet up etc. Not too sure about in VIC but it is legal over here in WA it just needs to be complied. Compliance is need when up grading to a motor with a capicity exceeding 25% of your old motor (BUT CHECK FIRST) If you were gonna get some seals, try Rare Spares they always seem to have everything ive ever need for my escorts. Or you could try make your own, Clark Rubber have been vey useful.
Hope this helps |
28-12-2007, 06:49 AM | #3 | ||
Its legal to put a 2lt into a Mk 1 Escort, but I'd recommend you upgrade the struts, including discs, calipers etc to Mk 2 spec. Get some out of a Mk 2 van and they are pretty much a bolt in job...swap the steering rack over as well.
Don't bother with the old BW35 Auto. Try and get a C3 box out of a later Escort. They are much better, you can still get inhibitor switches for them and you don't lose as much power as you do with the BW35. Personally, I'd ditch the auto as the 2.0lt really needs a manual to get the best out of it. Rare Spares do sells window seals but they aren't cheap. Someone told me they get them from a place call Old Scotts Rubber who are marginally cheaper and don't give you a smart- look when you mention you own an Escort. You can find both on the net. |
28-12-2007, 08:28 PM | #4 | ||
i bought new every single piece of rubber for the mk1 escort
this includes the bonnet stop rubbers and even pedal rubbers!!! paid about $600 or $700 from a place called Auto Hardware, but the shop is in Qld, sunshine coast....Kawana i think............ |
28-12-2007, 08:29 PM | #5 | ||
XA GT
Just to clarify, the 2L pinto that has been mentioned is the 2L that has the single overhead cam as found in cortinas and Mk2 escorts.
And are the engine mounts and so forth the same between the Mk1 and Mk2, will the 2L pretty much just bolt in the 1300 place. |
28-12-2007, 08:30 PM | #6 | ||
mod plate for the 2lt for rego
dont use the 1300 box as a 2lt one will fit and cheap as well |
28-12-2007, 08:32 PM | #7 | ||
the 2lt will bolt up to the mounts just
move the radiator forward a few inches use the whole 2lt frontend struts,rack and brakes |
28-12-2007, 08:36 PM | #8 | ||
yeah its the corty & mk2 2lt pinto
the whole mk2 2lt front end is in my mk1 i used the mk2 crossmember as well |
28-12-2007, 08:54 PM | #9 | ||
pics of the radiator mount for a 2lt conversion
good luck |
28-12-2007, 09:53 PM | #10 | ||
pretty easy swap,just make sure you use the escort 2ltr sump and oil pick up not the cortina one.
T2 TE50 no:154 Narooma blue AU2 XR8 ute XR4 fiesta |
