Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
18-10-2010, 11:47 PM | #1 | ||
I've fitted DBA 4000 front rotors and QFM HPX pads. No worries, 322mm x 28mm rotors. Great stopping, NO squeal and NO dust. Now for the rear.....
Picked up a pair of 328mm x 26mm DBA 4000's and QFM HPX pads (by the catalogue) to finsih the job, but, surprise - they won't fit! Rears as fitted (had the car from new) are 303 x 16mm solids, the same as the BA's and the non-turbo BF XR6. I understand the 303 x 16mm rear were supplied with 298 x 28mm or Premium 325 x 32mm fronts, but not the 328 x 26mm "upgrade" on the BF with the much smaller 303 x 16mm rear. Have you heard of Ford fitting non matching front/rear brakes on BF MkII XR6-T's? Can you offer an opinion on fitting the larger callipers to go with the 328 x 26mm rotors and pads, or try and swap them back for the originals (surprisingly smaller)? |
19-10-2010, 11:44 PM | #2 | ||
EL GHIA LIFE
for some reason (probably cost cutting) they went back to the smaller disc and caliper with then mk2. I too found this odd when i purchased my BF mk2.
SILHOUETTE 07 BF MK2 Turbo, FR19 SIMMONS, ZF AUTO, NIZPRO, GTX, CHINA BEIGE INTERIOR, /////ALPINE AUDIO, PEDDERS XA COILOVER'S. HERITAGE GREEN EL GHIA, ROH MODENA WHEELS, /////ALPINE AUDIO, PEDDERS XA COILOVER'S |
20-10-2010, 01:35 AM | #3 | ||
Seems so from other sources. There is apparently a revised DBA catalogue currently at press which hi-lights this change.
I've decided to change the callipers as I already have the larger rotors and pads. At least it will be ADR compliant. Yet another disapointing Ford let down. |
20-10-2010, 11:30 AM | #4 | ||
Race Brakes Sydney
Also the FG's have the smaller solid 303mm set up as well.
The rear PBR calipers to suit the 328mm discs are $150each caliper plus $80 for the HPX pads.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
20-10-2010, 12:13 PM | #5 | ||
preying on lions
will the bf2 hoses bolt straight up to the new pbr calipers,cheers
2014 FG2 Falcon XR6 luxury in Black, - New toy 2022 HD Lowrider S 124hp/136flb's |
20-10-2010, 02:38 PM | #6 | |||
Race Brakes Sydney
MATTHEW PEARCE
