Old 07-05-2010, 09:24 PM   #1
terryk
When Only The Best WillDo
terryk's Avatar
Default AU1 Master cylinder upgrade
HI All
I have fitted BA XR8 front brakes on the front and territory rear brake assembly they are great with the exception of the brake pedal feel due to the piston size increase in the calipers therefore requiring additional fluid from the master cylinder to move the piston the same amount. When I checked the PBR book the AU master cylinder is smaller than the BA, AU-PBR part# is B224-067 22.22mm/28.57mm verses BA PBR part# is B227-109 23.83mm/31.75mm. But the BA unit is slightly different.
After all that my question is what is the best way to go, can the AU unit be resized or can the BA unit do the job with a T for the pressure sw or something else??
Terry
terryk is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2010, 09:35 PM   #2
GS608
Is the AU Series 2/3 booster the same as the BA? you can fit that just have to drill new holes in the fire wall as the bolt pattern is different.
GS608 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2010, 09:43 PM   #3
terryk
terryk's Avatar
From what I can see the AU and BA/BF master cylinder will fit but there is a pressure sw in the front and underneath of the AU unit where the BA/BF unit has no prevision for the pressure sw's
Old 13-05-2010, 09:23 PM   #4
terryk
terryk's Avatar
Hi All
Has anyone had the factory AU master cylinder modified??
Terry
Old 13-05-2010, 09:46 PM   #5
Noddy
Mercury Silver T3
Noddy's Avatar
I am also interested in a modified or upgraded master cylinder. Will going to a larger bore mc reduce the amount of pressure required to apply to the brake pedal?
House of Tickford
T3 TS50 No.156
AUIII XR8 220
2017 Magnetic Mustang
What to hear a tuff T3?
Click here
http://s7.photobucket.com/albums/y30...ent=Movie2.mp4
Noddy is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2010, 12:19 PM   #6
XR Lita
XR Lita's Avatar
The BA b/m/cyl will bolt straight up, but you will lose cruise control for the AU. Going to a larger b/m/cyl will reduce the amount of pressure as it will be displacing more fluid with each application. It is not really required though. I am running Brembo calipers front and rear on mine, and have no dramas at all in regards to pedal effort.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
XR Lita is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2010, 11:18 AM   #7
Noddy
Mercury Silver T3
Noddy's Avatar
Thanks for the reply. My circumstance is a little different to most, i drive with hand controls so the brake pressure is applied through my hands hence why i am trying to reduce pedal pressure/effort/travel.
Why do you lose cruise control by going to the ba cylinder?
EDIT: i had a think about my last question, i guessing because you lose the pressure switch on the ba b/m/c the cruise has nothing to trigger its release when the brake is applied.
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
Old 18-05-2010, 01:40 PM   #8
mik
mik's Avatar
thats a good question Noddy, i`m putting b series stuff on my au also, the master cylander swap cruise control thing has me my interest too, if its the loss of pressure switch surely the cruise could be deactiveated by a brake light switch, if they don`t have them it would `nt be hard to fit one to the brake pedal i reckon.
Old 18-05-2010, 08:56 PM   #9
terryk
terryk's Avatar
But can the pressure switch be still fitted with a T fitting?
Old 22-05-2010, 12:04 PM   #10
terryk
terryk's Avatar
Here are some photos of the different master cylinders. What would it take to use the BF Master Cylinder?
Any assistance will be appreciated
Terry
Brake failure switch fitted under M/C & the cruise control pressure switch towards the front of the M/C
I think that is a fluid level sensor
Old 23-05-2010, 12:09 AM   #11
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Originally Posted by Noddy
........ i guessing because you lose the pressure switch on the ba b/m/c the cruise has nothing to trigger its release when the brake is applied.
Interesting thread here guys. Just thought I'd point out, cruise off is triggered from the brake light switch, the pressure switch trigger is a back up in the case when your brake switch fails, which it often does.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2010, 10:23 AM   #12
terryk
terryk's Avatar
Thanks AMB, so a 'T' junction will sort that out.
Does the BF have the brake failure sensor in the ABS unit or is that the sensor in the bottom of the fluid reservoir?
Old 06-06-2010, 12:44 AM   #13
terryk
terryk's Avatar
Anyone have any idea with respect to the use of a BF unit on an AU?
Old 08-06-2010, 06:31 PM   #14
mracoval
slightly off topic but might help. I've upgraded my series 1 au to series 3 ront and rear and found no significant difference effort wise but one thing I did notice was how much the plastic booster flexed while standing on the brake pedal. I experimented using cable ties around the master cylinder down to the upper control arm bolts to stop it flexing and increased pedal feel dramatically. Now to fabricate a bracket.
mracoval is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2011, 05:32 AM   #15
Daniel B
Daniel B's Avatar
Default Re: AU1 Master cylinder upgrade
Ok, time to bump an old thread.
To the OP, did you ever work this out, get it sorted?
Also, why did you use the territory rear brakes, were they a direct bolt on? Did you use the discs and calipers? and what model Territory?
Daniel B is offline   Reply With Quote Multi-Quote with this Post
