Old 22-01-2006, 11:01 PM   #1
Redrum
Force Fed Fords
Redrum's Avatar
Default ETAG Holders
Anyone know any easy ways/tricks to remove etag holder from inside windscreen?
2021 Focus ST-3 Mountune Enhanced
Redrum is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2006, 03:29 PM   #2
'63Deluxe
Irregular Member
'63Deluxe's Avatar
Quickest way(and dumbest) - Smash the windscreen
If its mounted on double sided tape use some fishing line to cut it off then:
The best way to remove stuff from glass is to use a new razorbade scraper with soapy water, and only scrape vertically. To eliminate scratches don't scrape back and forth, only in one direction. If there is any glue reisdue left then some turps or simmilar will remove.
Be carefull of the screenprinting on the glass!
'63Deluxe is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2006, 05:14 PM   #3
Redrum
Force Fed Fords
Redrum's Avatar
Cheers, will try all but first method.
Old 23-01-2006, 05:18 PM   #4
BlackLS
Posts: n/a
Eucalyptus oil is good as well
