Old 12-09-2014, 05:28 PM   #1
King Dribble
King Dribble's Avatar
Default Diff gears
What quick strip FG F6's are running stock diff gears?
1000hp Plazmaman FMIC kit. 660cc Blueprinted injectors. Modified turbo housing and actuator. Bluepower CAI. 4" X-force turbo back exhaust. Atomic valve springs and Herrod Motorsport 400 L/Hr in tank pump. Turbosmart dual port BOV. X-Cal 3 and custom tuned. Pedders sportsrider suspension. Lets call it 399.3RWKW. Extra trans cooler for protection. (I don't like milk)
King Dribble is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2014, 04:09 PM   #2
stevanford
Default Re: Diff gears
The standard 2.73 gears.
stevanford is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2014, 04:44 PM   #3
rednose
RNS10S
rednose's Avatar
Most ZF equipped cars retain the standard diff gears.
Even the 9 sec ones
The ZF cars are perfectly geared but you can always play with tyre profile.
BF Mk2 ZF Maintained by JSB Tuned by Autotech Engineering
GT3582R - 11.2 @ 128 on Nitto Invos - 10.9 @ 134 on ET Radials
PTE6235 - 11.0 @ 135 on Nitto Invos - 10.4 @ 140 on ET Radials
rednose is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2014, 10:32 PM   #4
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
Id go taller (lower numerically) if you could, as George mentioned you can go from 26 thru to 28 or even a 29+" tyre with the right clearance and front tyre diameter to match, with the added benefit of more contact patch on the road
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2014, 10:50 PM   #5
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
Daniel
Like the 2.53:1 ratio the BF 3V V8's came with?
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2014, 11:02 PM   #6
CAT600
CAT600's Avatar
I have seen it written in service manuals but never seen a gearset and every diff shop I spoke to that services these M86's says they have never seen an M86 2.53 but yes, that would work well
Daniel
Old 14-09-2014, 12:57 AM   #7
mburnz236
AFAIK all the 3v V8's were fitted with the M78, same as the NA 6's. So even if it is a 2.53 in the BF 3v it wouldn't fit.
Only the Boss and turbo's got the M86
mburnz236 is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2014, 01:04 AM   #8
FPV GTHO
That would make no sense though. BA Turbo's were only rated to 450nm and still got the M86, and 3V V8's easily made more torque than that.
Old 14-09-2014, 01:25 AM   #9
mburnz236
Apologies. I may have been thinking of the center bearing sizes between engine variants.
Just did a search and can find 2.53 in M86 size, but not in M78. So must be an M86 in the 3v's
Old 14-09-2014, 11:20 AM   #10
BFXT54L
BFXT54L's Avatar
Who wants to Buy my 2.53 M86 diff. 100% they were standard on BF 3Vs, not LSDs though....
BFXT54L is offline   Reply With Quote Multi-Quote with this Post
