Old 02-05-2016, 08:48 PM   #31
manchu
Default Re: Water Detected in Fuel...worry?
Originally Posted by ivorya View Post
Isn't it amazing that old diesel cars had a water bowl so you could visually look and drain water.
These new cars are all setup to fail
I guess the sensor and warning message is the modern equivalent of visible bowl.
I bet the vast majority (me included) of diesel owners are more likely to notice a warning on dash than anything under the hood, so Id say they're setup to avoid failure.
The issue now is the complexity and cost of the system. I wonder how frequent water sensor failure is and how much they cost to replace??
Edit: bet me to it NZ XR6
manchu is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2016, 10:55 PM   #32
Mondaveo
Mondaveo's Avatar
Originally Posted by NZ XR6 View Post
Also, it's very easy to drain some diesel from the filter and check for water.
Easy, if you can find it that is!
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift sensor: Nov 2016
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2016, 12:04 AM   #33
cobrin
Challenge Accepted!
cobrin's Avatar
You'll need to double check OP this is all I could find for another location: Scroll down to post #30
http://www.talkford.com/community/to...lem/?p=2263994
Old 03-05-2016, 01:17 AM   #34
manchu
cheers. hard to tell from that pic where I'm looking at. I think it's the same location as V8kado's pic (taken from right side instead of left).
I haven't found much on more recent MC's, but I did see that Ryco lists 2 filters for MC tdci (before and after 04/12).
http://www.rycofilters.com.au/catalo...ondeo#vnote_ik
Old 03-05-2016, 07:48 AM   #35
rondeo
It's the same as V8kado's. I posted the pics on talkford (I'm out of data allocation for pics here).
So per Ryco the filter is different after 04/12. Should be easy to spot, canister with fuel lines and electrical connector about the size of a jar of pickled onions. Could have migrated to the left side.
Old 03-05-2016, 08:37 AM   #36
Mondaveo
Mondaveo's Avatar
My Haynes manual (2012) says:
1.8 litre engines
The fuel filter is located at the left-hand end of the cylinder head. To gain access, remove the plastic cover on the top of the engine.
2.0 litre engines
The fuel filter is located under the rear of the car, behind the fuel tank.
We all have 2.0s, but maybe it could be in the position for the 1.8?
Old 03-05-2016, 08:53 AM   #37
manchu
I think it's moved to forward of fuel tank now. (See first photo I posted on 27/4, which is looking from right rear to left front) . Obstructed by heat shield and centre of car so pretty tough to access without lifting the car.
I had a good look in engine bay with cover off. Not there.
Old 03-05-2016, 04:45 PM   #38
bundybear75
bundybear75's Avatar
I think this may be the fuel filter in the later models (12/12 build)
Drivers side of engine under plastic cover
Close up. Not sure how you get to drain screw as it sits in a casing
Now on another note, where the hell is the oil filter??????
Spent an hour looking for it, nothing obvious.
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2016, 05:59 PM   #39
NZ XR6
That's a very different engine to the earlier models!
Old 03-05-2016, 07:32 PM   #40
manchu
Originally Posted by bundybear75 View Post
I think this may be the fuel filter in the later models (12/12 build).
Was looking at that with a mate. He thought it was the fuel pump??? Would be a ***** to drain if it is the filter.
Old 03-05-2016, 07:40 PM   #41
rondeo
Looks like a filter to me.
The fuel pump is driven directly off the exhaust camshaft on RHS, all metal, lots of pressure.
I'm guessing the oil filter is where it was before, which makes it underneath the filter?
Old 03-05-2016, 08:44 PM   #42
ivorya
Mad Scientist!
ivorya's Avatar
I think, where the oil filler is, you can unclip this long pipe.
Underneath you'll see a round object with a nut on top (all black plastic)
This is where the oil filter is. A real s__t to get to if you ask me!!
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2016, 08:51 PM   #43
ivorya
Mad Scientist!
ivorya's Avatar
I understand that these days people would prefer to get a message indicating an issue but as far as i'm concerned, who then has the time to book their car into their mechanic to drain the water?
Also, what tolerances have Ford put into the system before you suck this water through your system causing massive bills?
A simple glass/plastic indicator/bowl, with drain on bottom, could have been placed in the wheel arch (behind a flap). A simple message could be written in the manual telling you to check every month.
Old 03-05-2016, 10:30 PM   #44
bundybear75
If someone could upload a pic of one of the earlier engines with the cover clipped off I would be grateful. I understand the oil filter was to the right of the filler cap but I couldn't see it anywhere. I googled some images and found that the earlier ones had a filter underneath near the bottom of the radiator - I didn't notice it there when I pulled the splash shield off but I was distracted by an slight oil leak from my transmission.
2002 BMW R1150GS
Old 03-05-2016, 10:37 PM   #45
bundybear75
Just noticed the Peugeot and Citroen symbols on top of the filter next to the FoMoCo LOL
2002 BMW R1150GS
Old 04-05-2016, 12:13 AM   #46
NZ XR6
Yes, Ford and PSA share their diesel engines. The Mondeo diesels are made by PSA in France, and the V6 engines are made at Dagenham in England.
Old 04-05-2016, 09:33 PM   #47
Mondaveo
Mondaveo's Avatar
Here's my engine bay - sorry for the dark photos. 11/10 build.
Honestly - I would be like trying to get to that without your migratory fuel filter hovering in the vicinity...
Here're pages from the Haynes manual that helped me locate it:
Old 05-05-2016, 12:56 PM   #48
bundybear75
Found It (oil filter) !!
Hiding behind the filler tube, and almost under the fuel filter. I had to unclip the filler tube and lay it out of the way to get to the filter. Not sure how I will go changing it but I will find out in a couple of weeks.
2002 BMW R1150GS
