21-06-2016, 06:16 AM | #31 | ||
The one and only
I have whee lnuts come loose on three separate occasions with two different cars. You not a moan sound from the offending wheel, I don't know how you didn't notice that!
So in both cases I just pulled over and tightened them. Moral of the story, don't trust anyone else!
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
21-06-2016, 06:59 AM | #32 | ||
One of my work mates lost a wheel on his Prado the day after a service. They had taken his aftermarket wheels off for the usual checks and when they refitted them they (the apprentice??) never installed the clips for the center caps properly and the wheel worked loose. Slow speed at a busy roundabout in Canberra. No damage done when the wheel fell off but some done dragging the hub and shock mounts to get out of the way of traffic
They found two other wheels loose for the same reason and the dealer sent a tilt tray and carried out repairs free of charge. He was lucky, minutes before he was doing 100kph on the highway. Many years ago I lost two drive tyres off a heavy truck when entering a small town. Not sure where the first one came off (i never found the rim) but when the second came off I knew about it. Thought id done a clutch center as I lost drive. Turns out the steel hub doesn't get good drive on bitumen. This scared me, the thought of a 100kg plus full steel rim bouncing down the road towards on coming traffic at 100kph is terrifying.
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢 2008 Peugeot 308 HDi - Highway Hack II 2008 Citroen C4 HDi - Highway Hack III 2010 Peugeot 308 HDi SW - Shaggin Wagon II 2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power ! 2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone 2022 Volvo XC40 T4 Inscription - Shopping trolley II 2002 BMW R1150GS |
24-06-2016, 12:48 AM | #33 | ||
i saw a funny like that too many years ago , i was working in a holden service department at the time , one of the young apprentices did a drop the clutch wheelie in an FC sedan out the back on the cement entrance to the pits in a customers car , he turned the right hand axle into a perfect carrot , he then had to go an apologize to customer and Put a another axle and fit it at his own expense .
24-06-2016, 06:34 AM | #34 | ||
Always use a torque wrench on wheel nuts as the well run tyre places like Bob Jane do.
24-06-2016, 07:06 AM | #35 | |||
Yet to see any tyre centre get a torque wrench out.
4 users like this post: |
24-06-2016, 08:39 AM | #36 | ||
Boss 335
Yes, front wheel on my pushbike in high school. Some ***** thought it would be a good idea to undo the quick release on my GT bicycle while it was parked. Was gunning it down the street and and luckily the wheel somehow managed to barely hang onto the bike and luckily did not fly off and break my neck
24-06-2016, 12:58 PM | #37 | ||
I still remember the Day my Brother did a jump on his BMX & the front wheel came off
the look on his face
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
3 users like this post: |
24-06-2016, 01:13 PM | #38 | |||
24-06-2016, 03:00 PM | #39 | ||
R51 Pathy, 91 Jayco Swan
If the wheel studs are not damaged. Someone has taken off your wheel nuts.
24-06-2016, 03:02 PM | #40 | ||
24-06-2016, 03:18 PM | #41 | |||
*barks incessantly
Don't know if every shop does it but I've never worked for anyone that doesn't use one. |
24-06-2016, 09:33 PM | #42 | ||
I have personally had wheels come loose, been lucky that ive only had trailer tyres come off. I recently had the inner wheel work loose on the workshop hino. some of the trucks at work have a tension every 50 Km warning notice from factory.
through work I had to repair loads of vehicles that had lost wheels-but most only come loose an start braking wheel studs. Its normally the left drive wheel on vehicles that are manual transmission in stop start work. last one I saw was a patrol and had worn the studs half through without giving the driver and warning. Lot on medium trucks use left hand thread to reduce the risk of working loose. lot of the Japanese trucks use a single RH threaded nut on alloy rims. these depend on the hub being clean and true. I spent a day in the 90's tensioning wheel nuts in a holding yard post assembly line. A ambulance vehicle had a wheel fall off in service. The fault was powder coating in rims.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA- Land Rover 88 .MIDCOAST NSW.
24-06-2016, 09:47 PM | #43 | ||
tension wrench.
can buy a tension indicator for most wheel nut specs. normally a colour coded half inch drive item. most customers would know if it was used. Most bigger organisations Ive worked for had calibrated air tools, Most desperate for your business companies in the Q&A days would have you hand check each nut after the vehicle after it had been driven a short distance. These days they stick on the windscreen a indicator of repair and advise of a free retention. These days a tradesman doesn't have to be able to judge or calculate tension to be certified, that is considered to be a post trade certification called diagnostics.
25-06-2016, 12:54 PM | #44 | ||
Cruising...
Yes. Yes i have.
Wheel nut threads on the two nuts i found up the road when i was looking for my wheel were very ugly. Threads on studs were pretty average. Eventually somebody found my wheel in their front yard and brought it out for me. Wobble wobble thud. Thread needs more pics. Turns out it damaged part of the lower ball joint and went goofy on the way to the mechanic.
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 |
25-06-2016, 01:17 PM | #45 | ||
Then all the one's at Mt Druitt should be sacked ... never seen a torque wrench used there at all.
25-06-2016, 01:59 PM | #46 | |||
Need New Starter Motor
When you say calibrated air tools, is the applied torque then judged by the time the rattle gun is activated ? Just trying to get an idea of how it works. I always check the wheel nut torque after work is done on my wheels, and I have found huge differences in torque (usually over tightened). |
25-06-2016, 02:03 PM | #47 | ||
25-06-2016, 03:02 PM | #48 | |||
25-06-2016, 04:56 PM | #49 | ||
rattle gun normally are a hammer style and if serviced I would expect the only way to adjust the tension is with air pressure. so each bolt will be a different tension as most will have a small air capacity. I have a old IR 3/4 drive gun that will be within 10%.
an air ratchet often can be adjusted to a set max tourque. I come across very good electric units. few years ago tool sellers flogging tension calibration units because of contractors working on mine sites needing to prove that their tools met standards. tension bolts with lubrication of the thread-this allows the retaining method to be over clamped as you are measure rotation friction. also allows the nuts that appear tight can work loosen. I recommend lubrication/never sieze on the thread as most issues I come across is the thread is often damaged removing the nut/bolts or from dirt /rust.
25-06-2016, 05:49 PM | #50 | ||
G'day ... Early in 2015 I decided to drive my newly aquired BA Fairmont to a neighbouring town to put my Tattslotto tickets in.All was fine then I hit St Marys Pass , a 5.5 km stretch of windy road with steep banks and drop offs..I was about halfway down when....clunk , thump clank thump etc...I got to a place called the "quarry" , about the only place on the Pass to pull up and turn safely..I got out and couldn't see anything out of order so I decided to try and do the 10 kms or so back home..I never got above 20-25 kmh all the way and every so often the clunk noise returned. I got back eventually to our servo and the mechanic had a look around , and drove the car along the street , quickly hearing the noise..i left it there all afternoon and nervously went back up just before closing time to see what I was up for..Walked in to the office .."All good , all ready to go " he said..Turns out three of the five wheel nuts had come loose enough to cause the clunk noise on the offside rear wheel on the twisty road and the car was supposedly serviced about 10 days before when I picked it up..Luckily no damage to the studs or wheel/hub and a proper tighten fixed it all ..Could have been expensive and really dangerous..Cheers Rod..
25-06-2016, 10:37 PM | #51 | ||
All Bran = Regular Member
I lost a set of duals of a tri-axle trailer in the late 70's.
Hoofing down from Nebo along a development road, get to Dingo, kick the tyres....oops. I'm glad it happened out in the middle of nowhere. At 100kms an hour they'd demolish a house.
