Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
28-10-2015, 03:03 PM | #1 | ||
Race Brakes Sydney
We have had a lot of inquiries about the 328mm vented PBR rear upgrades which have the larger rear disc and larger rear pbr caliper on the BA BF FG model Fords and have put some packages here for you.
These kits are suitable for the rear of sedans,wagons and utes and are better paired with a 322mm or larger front brake kit.We can sell the kits less the hoses or with and also have options with RDA plain or slotted and dimpled or DBA plain,T2 or T3 rotors and many pad choices from street to strip. Prices of the various kit combo's we do have no hoses or right up to everything from $350 up to a full complete kit for $1100. Example of kits below One option is to run the DBA T3 rear 328mm vented and slotted disc rotor with the red PBR caliper along with braided lines and brake pads at about $995 a kit. (this kit is pictured) Another option is our cheapest and that is plain un slotted rear rotors with std street pads and red calipers with no hoses from $350 Available now and only whilst stock is available $995 kit is pictured
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
20-11-2015, 12:24 PM | #2 | ||
Hi Matt
Re. the 328 upgrade, im looking at the callipers, pads and T2 rotors. Also can I use my existing lines? Just after a price and if you have in stock as I can pick up. Thanks for your time Jase |
20-11-2015, 01:49 PM | #3 | ||
Lurking......
Do those calipers only come in red?
20-11-2015, 06:22 PM | #4 | ||
Race Brakes Sydney
MATTHEW PEARCE
23-01-2016, 12:58 AM | #5 | ||
How much would it be for the calipers, RDA dimple/slotted rotors and a decent street pad such as HPX or similar alternative posted to 2777?
Don't need lines as I've just bought and fitted a set of Goodridge brake line from you (great quality too!) I assume they would fit fine with the round banjo from the solid rear rotor caliper? Is it a noticeably better setup? Have only recently replaced rear discs and pads in standard size, so a bit hesitant to blow more money and replace near new items. Should have gone larger at the start
Current Viper 2010 50th Anniversary XR6T Stock, but for how long... Previous White 2003 Fairmont Ghia First- RIP. White 1990 Ford Fairmont Exhaust, intake, cam & lowered. |
23-01-2016, 09:27 AM | #6 | |||
Race Brakes Sydney
328mm Rear RDA S/D and red pbr calipers with HPX pads and delivery to 2777 is $545
MATTHEW PEARCE
08-05-2016, 08:56 AM | #7 | ||
How much for the calipers only. I just got the 6/4 brembo kit off you for my ba but unfortunately the rear rims dont clear the brakes.
Ill keep the 4 pistons aside for my next wheel change so ill put the pbr on for now until then
445RWKW of kennebell goodness |
08-05-2016, 11:06 AM | #8 | ||
Price with postage to 3047
Calipers braided lines pads and rda rotors? Will b paired to 6 pot brembos Sent from my LG-H340 using Tapatalk |
09-05-2016, 12:12 PM | #9 | ||||
Race Brakes Sydney
I have quoted RDA slotted and dimpled and that you car is a sedan with traction control. If you have anything different the price may change so you could spend $720 or up to $850 with freight. Quote:
Lets us know how you go with the wheels
MATTHEW PEARCE
09-05-2016, 12:14 PM | #10 | ||
Hi its for an AU s1 ghia so traction control& irs
09-05-2016, 02:24 PM | #11 | ||
Race Brakes Sydney
Did you change the front end to a series 2 for the Brembo conversion ? i do not have the specs for the AU S1 rear hoses so you may need to work with me on this one and they are a little dearer.
MATTHEW PEARCE
10-05-2016, 08:12 AM | #12 | ||
Its s2-3 front suspension
My mate has a s2 so i can check the lines and see if they are different Sent from my LG-H340 using Tapatalk |
10-05-2016, 09:59 AM | #13 | |||
Race Brakes Sydney
I can make every Ford rear hose once we get the correct set up.
MATTHEW PEARCE
30-06-2016, 07:33 PM | #14 | ||
How much for just 328mm PBR red calipers?
01-07-2016, 12:07 PM | #15 | ||
Race Brakes Sydney
I have a couple of red pair left @ $220 a pair thanks
MATTHEW PEARCE
13-01-2017, 10:58 AM | #16 | ||
13-01-2017, 11:30 AM | #17 | ||
14-01-2017, 09:58 AM | #18 | ||
Race Brakes Sydney
All the 328mm rear kits are basically the same on the rear of the BF or FG just the hoses that are different and yes they fit the majority of 17" wheels.
MATTHEW PEARCE
14-01-2017, 08:31 PM | #19 | ||
Thanks, Do you have any calipers in stock for the 328mm rears (assuming the fit my BA XR8 stock 17" rims), and price please.
16-01-2017, 09:48 AM | #20 | |||
Race Brakes Sydney
Yes we do have a set left and these ones are $240 a pair at the moment.
MATTHEW PEARCE
16-01-2017, 10:51 AM | #21 | ||
16-01-2017, 01:35 PM | #22 | ||
Race Brakes Sydney
Not a problem or a pm is ok as well
MATTHEW PEARCE
26-04-2017, 02:52 PM | #23 | ||
Any of these campers left?
Regards 5LXHR8 Daily- AU 2 Fairmont Wagon V8 Toys- T3 TS50 build 211 - 67 XR ute |
26-04-2017, 04:57 PM | #24 | ||
Race Brakes Sydney
Yes i have a set available.
MATTHEW PEARCE
26-04-2017, 05:03 PM | #25 | ||
And if I've got this correct I'll need a set of 328mm rotors to use or can I use these with my standard brakes on my series 1 BF? And will they fit the braided brake lines I just ordered through you via phone an hr ago? Sent from my iPhone using Tapatalk
05-07-2017, 11:02 PM | #26 | ||
Hi im after the full kit of T3 rotors, PBR calipers, pads & braided lines any kits available
Sent from my SM-A520F using Tapatalk |
06-07-2017, 09:40 AM | #27 | ||
Race Brakes Sydney
So the complete rear 328mm kit only and is it for a BA BF FG sedan or ute with or without traction control thankyou.
MATTHEW PEARCE
06-07-2017, 03:39 PM | #28 | ||
06-07-2017, 06:00 PM | #29 | |||
Race Brakes Sydney
Will have Red 328mm pbr rear calipers x 2 DBA T3 rear rotors x 2 Wagner rear brake pads Braided rear brake lines.
MATTHEW PEARCE
06-07-2017, 07:31 PM | #30 | |||
But plenty of spirited driving Also want to flush the brakes would 2 bottles of the A.P racing do the job And are the wagner pads performance orientated or only for street duties All freighted to 4226 cheers Sent from my SM-A520F using Tapatalk |
