Old 01-07-2022, 05:24 PM   #1
Canino
Default Ford xc steering column
I have lent over steering column and it's pushed itself in at bottom where it bolts to the coupling.. now I can't get it out. Any ideas?. I'm assuming it collapses in on it self if you where involved in a crash. Not sure how they come apart buy I assume it needs to so it can be reset. Cheers the colour was out of the car when this happened to
Canino is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2022, 07:08 PM   #2
73 4V XB
Frankenford pilot
73 4V XB's Avatar
Default Re: Ford xc steering column
The bottom part of the column is collapsible. Put it between you feet and lift the column up, it should pull out.
Cheers Bretto
73 XB GT
Last of the Big Ports
73 4V XB is online now   Reply With Quote Multi-Quote with this Post
Old 01-07-2022, 07:24 PM   #3
Canino
It's a bit tight, I will try an anchor it down somewhere and try pull it that way. Cheers.chris
