Old 14-09-2022, 10:26 AM   #1
Interceptor
HSV - I just ate one!
Interceptor's Avatar
Default Wheel alignment correction query....
When wheels with a bigger offset (40mm+) are fitted, should the wheel alignment specs change to accomodate how the steering and front suspension behaviour changes?
I've noticed on 100 series landcruisers the steering tends to pull to whichever side you're turning when you get closer to full lock, and the tyres start wearing oddly compared to before the offset change, so I'm wondering if this is something that can be corrected with modified wheel alignment specs
Interceptor is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2022, 01:11 PM   #2
Bossxr8
Peter Car
Bossxr8's Avatar
Default Re: Wheel alignment correction query....
In theory no, because the suspension isn't changing at all. But you can manipulate the wheel alignment to correct issues.
But someone might suggest otherwise, I don't know.
Old 14-09-2022, 03:41 PM   #3
GCRXR6
GCRXR6's Avatar
Offset changes the scrub radius. A small offset has little affect, but large offset, which 40mm would be approaching, would have some effect.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better!
GCRXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2022, 04:29 PM   #4
Tassie f100
I suppose that is why the legal max offset is 25mm
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2022, 07:45 PM   #5
GCRXR6
GCRXR6's Avatar
As well as the extra stress on the components.
