gday guys my series III xr8 au is playing up. the problem happens when a whine come from the motor alot like a supercharger, the car then looses alot of of power and dropping cylinders misses and carrys on. this happens very randomly sometimes high rpm mid rpm and low rpm with and without load
cheers guys. |
Next upgraded Mk1 Leopard
Have you done the usual ie checked/changed spark plugs, checked/changed fuel filter, checked/changed leads?
Uk
Need to do a fault code diagnostics check & see what comes up!
Never drive faster than your guardian angle can fly but fast enough so the devil don't catch you! |
#4 | |||
CNC fixer guy
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
Leads and plugs have been changed. About 5 codes come up relating to do with everything coil packs but like I said only happens when supercharger sounding noise comes from the motor
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
I am with Mif. Sounds like a cam sync, with the exact same behavior I experience when I stipped a cam gear (that drives the cam sync).
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
5.6L x 2 pilot
Muzza, cam sync is the under your coil pacs on a AU V8. It is where your distributor would be if it where in an older car.
This is him: ![]() Your best option would probablly to import one from the US and have a mechanic fit it up for you (half hour job). This one is known worker on our engines. http://www.rockauto.com/catalog/more...641&cc=1304435 Cheers Stu
4 users like this post: |
Thankyou to everyone who helped ended up replacing cam sync and harmonic as that was on its way out too. The car is like brand new smooth as a new car and power has increased significantly so cheers guys much appreciated
Thread Tools | |
Display Modes | |
