Old 02-11-2015, 07:57 PM   #1
GASWAGON
Default Best way to wash K&N air filter?
My BF I6 has the K&N flat style replacement filter fitted and I hav'nt washed and re oiled it since i've owned the car (15,000k's).
Just wondering whats the best solution to wash the filter in? Hot soapy water?
Or maybe some petrol or carbie cleaner in a spray can???
ALso I'm pretty sure i can buy the replacement filter oil from somehwere like Autobarn yeh???
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2015, 08:12 PM   #2
Jack960
Jack960's Avatar
Default Re: Best way to wash K&N air filter?
Supercheap and autobarn usually sell a kit which contains a cleaning solution and the oil
Jack960 is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2015, 08:15 PM   #3
Powdered Toast Man
Professional Mouse Jockey
Powdered Toast Man's Avatar
Go buy a K&N "recharge kit" its a pack that contains the oil and the wash. Yes you can get it at Autobarn and Repco and probably Supercheap etc. I've washed mine at least 10 times with this wash (filter has done over 200000kms in my car).
Hot soapy water wont cut it, i know i tried. You basically need a degreaser since its coated in oil.
Isuzu MUX for towing horses - currently no Fords in the stable
Time flies like an arrow; fruit flies like a banana. Groucho Marx
Powdered Toast Man is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2015, 08:15 PM   #4
NTF6
You'll most likely trash it if you wash it in petrol of carby cleaner, I've done mine a few times and I use the K&N filter cleaning kit which I find does an awesome job.
2017 Mustang GT (Magnetic)
NTF6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2015, 08:25 PM   #5
GASWAGON
O.k great info fella's......does anyone know how much the recharge kit costs?
I'm a bit broke at the moment!
Old 02-11-2015, 08:34 PM   #6
marcosanga
Ive used a very soapy hot water solution and find it works great.
Need something strong like truck wash thats quite alkaline mix it up nice n soapy with hot water.
Let it soak for a good while so it dissolves the grime and loosens up nicely then swish it up n down through the water so it pushes out all the dirt.
Dont use petrol or any solvents.
But do use the recommended K+N filter oil a few light coats will let the oil have time to soak into the filter
2005 BA Mk2 XR8 6SP in Velocity Blue, Full Premium Pack
marcosanga is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2015, 08:38 PM   #7
Powdered Toast Man
I bought one a couple of months ago from Repco. It was $25 on special. But I have payed more like $40 in the past.
Old 02-11-2015, 08:39 PM   #8
STINKY NINJA
Genuine k and n recharge kit is about $30 roughly,make sure you get the spray on oil and not the squeezy bottle.
Let it drip dry in the shade so the gauze doesn't degrade in the sun,will most likely take overnight to dry.
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2015, 08:45 PM   #9
GASWAGON
O.k $30 is pretty cheap.
Will use compressed air to lightly/ carefully dry filter after washing.
Thanks for alll the help fella's this site is the best!
Old 02-11-2015, 08:54 PM   #10
EB#
EB#'s Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Constant helpful advice and step by step guides in easy to understand format with pictures.
Cleaning a panel air filter:
http://www.fordforums.com.au/showpos...&postcount=187
EB# is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2015, 09:00 PM   #11
39ClevoUte
39ClevoUte's Avatar
I use a kero bath first. Then once pretty dry rinse in a kero bath with about 50mm of engine oil in it. wait till it "drys" off and all done. Cost about $10 and can be used again and again.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2015, 09:19 PM   #12
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Pop it in the dishwasher
Don't re-oil it
No Bull ...
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2015, 10:34 PM   #13
Silver Ghia
Silver Ghia's Avatar
Easiest way is to just replace it with an OEM paper filter. Done.
Couldn't be bothered with K&N air filters any more. They don't do much anyway except make more induction noise.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2015, 12:19 AM   #14
STINKY NINJA
You are wrong and your opinion is not needed in this thread,its about cleaning a k and n panel,unless you have helpful advice best to move along...
There is a couple of you guys who are k and n haters,maybe you could start a support group?
Old 03-11-2015, 12:43 AM   #15
uniacidz
uniacidz's Avatar
Normal degreaser I use in a aerosol
Then I do use the red spray oil by K&N
Does the trick
Sent via HTC Velocity + [HolicsROM v1.3] [SWEEP2WAKE]
Before -
ED Falcon Futura (sold)
EL XR6 (R.I.P.)
VX SS (R.I.P)
VE Berlina
uniacidz is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2015, 12:43 AM   #16
Feathers
Lucifer's Angel
Feathers's Avatar
I really hope that's sarcasm, or else it was a pretty OTT reply to a simple statement of opinion.
I use a light spray of degreaser and rinse with water.
Then dry it off with the air gun, and oil with air tool oil.
SINISTER BA XR6
Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford...
It's being beaten by a girl driving a Ford
Feathers is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2015, 01:35 AM   #17
baboon
Contributor: For members who make a contribution worthy of recognition. - Issue reason: went to the trouble of posting up some great Vids of the AFF drag meet
I use a container of warm soapy water and I've had mine soaking for about 5 years now, during that time Im using OEM whilst it finishes cleaning for another 5.
baboon is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2015, 11:31 AM   #18
Bossxr8
Peter Car
Bossxr8's Avatar
I bought one a few weeks ago for $20 at Autobahn. Apparently that is the new price for them.
Old 03-11-2015, 11:38 AM   #19
Silver Ghia
I was only going by my experience with panel filters in otherwise standard I6's, and I don't hate K&N air filters.
However, my hopefully helpful advice which I haven't seen mentioned yet clearly here, is that it is imperative to make sure the filter is rinsed from the clean (top) side, so the dirt goes back out from the side it came, and not forced through the filter. I use the K&N cleaner that works well.
Old 03-11-2015, 11:52 AM   #20
STINKY NINJA
Hope all you want buddy
Old 03-11-2015, 11:59 AM   #21
STINKY NINJA
For a technical contributor it was a really unhelpful post,you are meant to be helpful to people asking for advice,he only asked about cleaning,not your opinion on paper vs k and n
You basically said k and n are bin worthy,awesome help...
Old 03-11-2015, 02:10 PM   #22
Jack960
Jack960's Avatar
No need to get aggressive mate. When I read what he posted I didn't take it the same way. He simply said the benefits may not out weigh the hassle of k&n filters (the regular cleaning and 're oiling of the filter).
If someone were not overly fussed about filters and wasn't chasing any performance (installing a k&n will not yield and noticeable increase in power) I would recommend the paper filter as it is much easier to renew.
When cleaning you must be sure to remove all debris and also make sure it is 100% dry to make sure the debris doesn't get sucked through the engine. When 're oiling you must make sure you don't over oil it otherwise you will suck up heaps of oil into the intake or under oil it otherwise dirt will go straight through.
I can see why the paper filter is better in some cases.
Old 03-11-2015, 03:26 PM   #23
Road Games
Road Games's Avatar
I used to do the same Gerardine
Now its dishwasher air dry and refit . sure it doesn't look pink anymore but it sounds ace and the engine oil doesn't discolour that quickly like some reckon...
I gave my filter clean kit away... Normal degreaser works ace as well
Peace out ...
Old 03-11-2015, 03:28 PM   #24
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Best way to wash K&N air filter?
Here's how the manufacturer recommends doing it.
http://www.knfilters.com/cleaning.htm
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2015, 03:55 PM   #25
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
How dare you bring logic here.
Silhouette BF MKII F6
Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2015, 04:26 PM   #26
Peuty
Afterburner + skids =
Peuty's Avatar
Stinky Ninja must be off his meds today.
I use the standard recharge kit. No dramas here at all.
Oo\===/oO
Old 03-11-2015, 07:23 PM   #27
Revolver
Big Member
Revolver's Avatar
Absolutely.
OP, the instructions are on the recharge pack. Follow them and you are sweet.
Only thing is I ran out of oil about 3 washes short of the cleaner. So I went ahead and bought a bigger can of oil, it was a little more than a new recharge kit. Both cleaner and oil can be bought separately.
This thread has reminded me that I need to do mine.
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing
Rollin' on genuine ELGT wheels.
K&N Filter
/////Alpine Sound.
EBGT Momo Woodgrain Steering Wheel
The Scarlet Fairlane Build Thread
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
PWK Build Thread
1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile.
Revolver is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2015, 07:26 PM   #28
Express
Bathed In A Yellow Glow
Express's Avatar
Originally Posted by Revolver View Post
Absolutely.
It reminds me to do the same.
To those who blow air through them I thought that was a big no, no?
Express is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2015, 07:41 PM   #29
Silver Ghia
Yes. The Instruction leaflet that comes in the cleaning kit has in bold letters:
CAUTION; THE USE OF ANY OTHER DRYING METHODS (IE. COMPRESSED AIR, DRYER HEATERS, HEAT GUNS) COULD DAMAGE FILTER.
If you look closely at the filter construction, you can see why it would damage the filter.
Old 03-11-2015, 07:50 PM   #30
78xcgxl
78xcgxl's Avatar
I agree paper filter work and do the job. I change mine every 20,000km and done.
78xcgxl is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
