02-10-2006, 05:42 PM | #1 | ||
hello every one!
I have just recently purchased an automatic AU XR8 99 model, paid way too much but thats the price ya pay when you dont want to buy a boring old commodore!!! Any way my problem is this when i test drove the car it was fine(i even took it for two test drives),but then two or three weeks later when i start the car and then drive off car somehow falls out of gear but only when then engines cold,it doesnt fall out of gear when the engine is warm...then when im driving along in between up gear changes sometimes the engine revs way past where it should to change gears and when it does i get "clunk" sound and the car jolts.... if anyone could please help me out cos i dont know if its the gearbox or diff so an experienced mind would be greatly appreciated!!!!! Thanks!!! |
02-10-2006, 06:23 PM | #2 | ||
Welcome to the forums. The best bet I think if your after an answer is to post this in the AU Falcon section. There is a wealth of information in that thread. Ask one of the Admin team like Laminge to move your thread there. Good luck
FG2 XR6T KIA Cerato 2022 Kawasaki Z900
02-10-2006, 06:37 PM | #3 | ||
Sillouette MkII XR8
I had a 6cyl AU2 and the problem your having sounds like a problem I had with my car. The transmission oil was low in mine causing the problems you're refering to,...ford will want to charge you a couple of hundred dollars to plug in to their u beaut gearbox oil recycler doovalacky. I just got them to top up the oil in mine and it was fine.
SILHOUETTE BA MkII XR8 Ute.........RIP Neutral Turf for Now - '06 GLXR 3.2lt Turbo Diesel Triton FPV & XR OWNERS CLUB OF ACT (Inc)
02-10-2006, 08:21 PM | #4 | ||
Keeping Wombats Dead
Get them to flush your transmission system and tell them the problem you're having with the hard shifts. If its the problem I'm thinking off, its the S5 solenoid that needs replacing too
02-10-2006, 09:12 PM | #5 | ||
The Mandarin Monster
Definately sounds your transmission is low on fluid for a start.
If it has trouble with colder transmission temperatures and seems to rev up and clunk into gear, its possibly just low on fluid. It wouldnt do it when its warmer, as the fluid becomes a little more viscous when its hot and allows the transmission to build up pressure. Try topping it up and see how that goes! Might be a really cheap fix!
www.unekefurniture.com 288rwkw of EDIT POWER Go You Good Thing!! Click here for the FPV and XR Club ACT Website |
Thread Tools | |
Display Modes | |
