06-12-2006, 05:30 PM | #1 | ||
Hi Everyone,
I treated my 'good lady' to a 2004 Zetec Auto a few months ago and although she is very pleased with the car, it has a niggling problem on start-up. On the initial start in the mornings, the engine speed is 'hunting', therefore when you select 'Drive' or 'Reverse' the car jumps about for the first 20-30 seconds and then it's fine. Any ideas would be much appreciated. Thanks in advance, Mike |
06-12-2006, 05:38 PM | #2 | ||
What do you mean by "the engine speed is hunting"? When I start my car in the morning it normally idles at 1000rpm for about 1 min or so, and then goes back to 750rpm.
But even if I was in a hurry, my car didnt "jump" when I select "R". Maybe bad fuel? |
06-12-2006, 06:22 PM | #3 | ||
The idle speed flicks between 1400 and 1000, hence causing the car to kangaroo down the street when no gas applied!
Already been to Ford dealer...they're as much use as a "handbrake on a canoe"!!! Cheers, Mike |
06-12-2006, 09:08 PM | #4 | ||
Non-Regular Member
Could simply be a ECU issue. Reflash the ECU it sounds like a Cold enrichment and idle speed calibration issue.
06-12-2006, 11:20 PM | #5 | ||
LPG > You
When I start my car (05 Zetec WP), it sits at 1250rpm while the temp gauge is on stone cold. Does this for about 2 min. Temp gauges jumps up, slows itself down to 1000rpm, then eases down to its normal 750rpm idle.
LPG Lovers Association President & Member #1. : |
07-12-2006, 12:26 AM | #6 | ||
Air Flow Meter possibly? RPM hunting can sometimes be caused by a faulty AFM.
07-12-2006, 12:46 AM | #7 | ||
Non-Regular Member
Fiesta uses MAP sensor
07-12-2006, 12:56 AM | #8 | |||
