Old 07-04-2007, 01:24 AM   #1
AU2 Pursuit Ute
Fords : outlast Religion
Default XR8 Ignition Timing
If I elongate the mounting bolt holes in the timing pick up could I get more advance? What U think?
AU2 Pursuit Ute is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2007, 11:26 AM   #2
charles_wif_xf
Purveyor of filth
Refresh my memory: does the XR8 have dizzy ignition or coil pack?
charles_wif_xf is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2007, 11:51 AM   #3
AUXRVIII
Not 100% sure but if you did you might get 1 degree more advance by elongating the holes, what about using some sort of adjustable adpter plate?
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2007, 12:56 PM   #4
AU2 Pursuit Ute
AU2 XR8 has twin coil packs and a trigger at the harmonic balancer. The trigger is has 2 mounting bolts (these are the holes I would like to elongate)
AS AUXRVIII suggests some sort of adapter plate would be ideal, has anyone done this? Or can they give me a 'Heads Up' warning or suggestion? Thanks .... Dave
Old 07-04-2007, 03:46 PM   #5
Sledgehammer
Sledgehammer's Avatar
Try an aftermarket computer or AU Edit....
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2007, 04:05 PM   #6
AU2 Pursuit Ute
Having a day off work and a spare $1500-$2000 in the pocket at the same time is more difficult than tampering with a trigger location. That is until Lotto gets its **** together and calls out the right numbers
Old 07-04-2007, 05:11 PM   #7
AUXRVIII
Better not forget that you will be changing the timing in all conditions and not just peak advance and that may have a negative result on performance and/or durability.
Old 07-04-2007, 05:23 PM   #8
AU2 Pursuit Ute
Base Timing is what I am after, just to give more Torque down low. Chasing performance, Fords have always been durable for me no matter how much punishment I have dished out I have never worn one out or blown one up. Tried chevs, blown em all up.
