Old 30-03-2005, 11:30 AM   #1
double_d
Posts: n/a
Default 1980 eski van
i am just about to acquire a eski panel van
sounds better tham buying !!!!!!!!!
but was just wondering what sort of common problems should i look out for
i have seen the car and it looks straight with no rust engine starts and idles nice
has an EEEEEEEEEEEEWWWWWWWWWWWWW auto that changes seems to be fine
but as the car is unregistered i could not drive it
but not to worried if i have to spend a couple hundry to get it right
thankyou
daniel
Old 30-03-2005, 12:15 PM   #2
kiwikid
have you seen my marbles?
kiwikid's Avatar
rust in the heater dome..
bushes all round are proberly fukked..
wheel bearings..
comfortably numb...
kiwikid is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2005, 01:14 PM   #3
rag top
rag top's Avatar
Is it a 1.6 or a 2.0??
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
Old 30-03-2005, 04:50 PM   #4
double_d
Posts: n/a
it is a 1.6 litre
bushes and wheel bearings dont worry me
i didnt se rust in the heater box looking around firewall
Old 30-03-2005, 11:30 PM   #5
kiwikid
kiwikid's Avatar
you wont see it, it will be inside the actual dome thats if there is any rust..
comfortably numb...
Old 31-03-2005, 12:55 AM   #6
rag top
rag top's Avatar
Tip a jug of water down the front of the windscreen. If water appears on the carpet covering the footwells, then you have rust in the bulkhead/dome....
Current Rides:
Old 16-04-2005, 08:13 PM   #7
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Im not looking forward to doing this myself when i pic up my Van.
Same thing, "80 MKII 2lt 4speed.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2005, 08:03 PM   #8
LuvinmyEB
Beware of mood swings!
LuvinmyEB's Avatar
Location: Western 'burbs, put your bullet proof vests on!
I have that problem in the Mk I Esky, can just see the hole but it lets a hell of a lot of water in. Seal it as soon as you can (if it does leak) or keep your Esky under cover all the time.
1993 EBII GLi Auto, 4.0L MPI rebuilt by JMM, JMM Dev1 kit, JMM Hi Flow Cat, still to hit the quarter mile.
LuvinmyEB is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2005, 09:37 PM   #9
buickman
buickman
buickman's Avatar
They rust out in the phlenum chambers.To properly fix it you need to cut the bulk head of to cut the rust out and panel patch in another or a easier fix is to pull the heater and under dash bolt ons and clean and fiberglass it then paint it with a sealer. Leaves and muck gather around the air vent opening and over a period of years it gets rust holes in it. The only cars I've seen without the problem were cars that had been garaged most of of the time.
buickman
buickman is offline   Reply With Quote Multi-Quote with this Post
