Blueprint of Perfection
Well......its a sad day, my engine was pulled out last week due to a problem with blue smoke blowing out of the right bank under de-acceloration. The engine was stripped down and this is what i found. The oil pump was stuffed also due to metal parts in the sump and it had picked alot of it up and chewed out the internals. While all that was happening, i found that it had started to blow a head gasket between 2 cylinders on the block side, the heads were done 6 months ago, but Engine World found that the deck on the block was not flat and hence the blown gasket. Also what was found that 3 valves were working there way through the retainers and on there way to dropping through. So today has not been a good day for me, and it will be a little while before the black money pit will be back on the road
HIS 426 RWHP / 1100 NM OF TORQUE 393 CLEVELAND AFD 2V CYLINDER HEADS 1974 XB COUPE NO TRACTION AT EASTERN CREEK HERS BOSS 260 03 XR8 SEDAN COLD AIR INTAKE BY PERFORMER SHAKERS FULL X-FORCE QUAD TIPPED EXHAUST SYSTEM Last edited by thunderoo; 11-04-2007 at 10:15 PM. |
Noctunral by nature.
sorry to hear mate, hope u get her back on the road soon.
98 Au V8 Forte (1500 kilo car) LSD, Pacie comp extractors into pacie cats into lukey 3" exhaust, New ecu, Powerbond street balancer, injectors, tyres (on 17" tickford rims form factory) Slotted and cross drilled rotors front and back, New radiator and hoses new crank position sensor and cam sensor plus gear, new leads and iridium plugs and new accel coil packs. New S5 solenoid. plus flash tuner (SCT X3 flash tuner) |
sorry to say but most engines i've seen with broken piston lands have had detination problems!!
Captain beat down
That sucks mate, when its all back up and running with a stroker kit, it will be worth it.
oooh bugger. That sounds nasty! Also sounds like multiple problems, I wouldn't expect that from a fairly recently built engine.
mmm... stroker kit sounds nice. It'll definitely be a monster when you get it back on the road. So the shopping trolley is coming for another cruise, lol. Looking forward to seeing you all on Sunday. I hope everyone else is as bad as me at bowling... Rob.
2005 BF XR6 - Vixen Red with Silver Stripes - ZF 6 Speed Auto - 19'' Chrome RJRs - 197.7rwhp (stock)
#6 | |||
HIS 426 RWHP / 1100 NM OF TORQUE 393 CLEVELAND AFD 2V CYLINDER HEADS 1974 XB COUPE NO TRACTION AT EASTERN CREEK HERS BOSS 260 03 XR8 SEDAN COLD AIR INTAKE BY PERFORMER SHAKERS FULL X-FORCE QUAD TIPPED EXHAUST SYSTEM |
#7 | |||
Yes the shopping trolley will be brought on the next few runs unfortuneatly.......oh well, all i know that now when shes back on the road as a 383 and John from Engine World is doing a few tricks himself, shes going to be more of a screamer than before !!!
Off tap Truckie
geez what a shame. We must be in the same boat. My motor is nearly finished. if ya need heads or a cam. I have a set. And if ya need a clevo flywheel, ring my john up cause i know he has one brand new. they sent wrong one to us. Talk soon mate. Gotta keep driving the new truck.
T3 TS50 Brembo's,AFR 185,Platuim Rockers,Haltech,MSD,Custom exhaust
![]() ![]() 1968 KC Bedford 1970 Mk1 Escort GT 1980 Mack Superliner 120t: Project Puppy Dog! AU2 XLS Cab Chassis, 5ltr, T3 Kit, Speedy Envy's 19x8.5 |
The Beast
o well when it comes to valla weekend she will be turning a few heads & eye balls. End result you will be having fun. TEX.
Still alive & kicking
Not good Gordon makes me think i should have a compression test done on mine been pinging for awhile even after a tune up you got me thinking.
EL XR8 made to burn rubber :evilsasmo IN THE BEGINING THERE WAS TICKFORD |
The 383 has been canned!!!!! HAHAHA John and i agree that a 393 will be better !!! So the 393 has been ordered WEEEEEEEEEEEEEEEEEEE comes with a Scat forged steel crank, Scat forged Hbeam rods and SRP forged flat top pistons !! Now the 2V heads that ive spent a fortune on are being scraped also. Now im am purchasing AFD alloy cylinder heads and having them sent out to Goodman race engines to have ported and flowed. The rest of the gear that i need, i alredy have....... cant wait to get her together, John from Engine World says we shoul get around the 550 HP mark.....i just cant wait to leave marks.
#12 | |||
#13 | ||
Off tap Truckie
whats happening with the buld mate. no info at all
![]() ![]() ![]() brian
