Old 24-06-2007, 07:44 PM   #1
Bossxr8
Peter Car
Bossxr8's Avatar
Default VE crashes worse than VZ
Anyone see the GoAuto story about how the VE has a lower overall score than the VZ in the ANCAP crash tests. Not by much, but after all the talk of the high strength steels etc etc they fitted to the VE, the side impact was considered worse than the VZ. So much for progress. But Holden consider the Barina crash test acceptable I spose.
Old 24-06-2007, 07:53 PM   #2
Smoke Pursuit
Wonder whether the side airbags were fitted to the car that was tested?
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Old 24-06-2007, 08:06 PM   #3
stevz
I cannot see how it is possible for the VE to be worse than the VZ, however it is obvious there are definitely some inconsistencies in these ancap tests.
Here they rate even the EF/EL safer than the BA. Please explain?
stevz is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2007, 08:14 PM   #4
stevz
Another inconsistency
The Holden Barina scores 4.39/16 in the offset test and 10.57/16 in the side impact test to achieve a 2 star rating.
The Daewoo Kalos scores 5.90/16 in the offset test and 11.73/16 in the side impact test to achieve a 3 star rating.
Now these are EXACTLY the same cars. Why the inconsistency?
Old 24-06-2007, 08:44 PM   #5
Bossxr8
Peter Car
Bossxr8's Avatar
I'd assume because its a single test and that every car is different. Plus there would be a few differences between both those models of Daewoo, the Kalos is fairly old now, and would have had a number of changes since it was released.
Old 25-06-2007, 07:06 AM   #6
MAGPIE
MAGPIE's Avatar
The scoring rating system has changed since the EL
Summary: Ford Falcon 1997
* Overall rating:
* Marginal
* Airbags: Driver's Airbag
* Engine:
* Kerb weight: 1560 kg
* Test vehicles built: Aug 1994 & Sept 1997
* Crash test date: Dec 1997
Summary:Ford Falcon 1998
* Overall rating:
* Acceptable
* Engine:
* Kerb weight: 1530 kg
* Test vehicles built: Aug & Nov 1998
* Crash test date: Feb 1999
Summary: Ford Falcon 2000
* Overall rating:
* (3 star)***
* Airbags: Dual Front Airbags
* Variant: Forte Sedan
* Engine: 6 Cyl. 4 litre. Auto.
* Kerb weight: 1550 kg
* Test vehicles built: October 2000
* Crash test date: May 2001
Summary: Ford Falcon 2002
* Overall rating:
* (4 star) ****
* Overall score: 27.27 out of 37
* Variant: XT sedan
* Airbags: Dual front airbags
* Engine: 6 cyl. 4L
* Kerb weight: 1690 kg
* Category: Large/Medium
* Test vehicles built: October 2002
VE for comparison to BA (pretty poor for the VE imo)
Summary: VE 2007
* Occupant protection:
* (4 star) ****
* Occupant protection score: 27.45 out of 37
* Pedestrian protection rating: (1 star) *
* Pedestrian protection score: 8.98 out of 36
* Engine: 3.6 V6
* Variant: Omega Sedan
* Category: Large car
* Kerb weight: 1700 kg
* Test vehicles built: 7/06 and 10/06
* Test by ANCAP
A 5 Star car for comparison:
Summary: Subaru Legacy 2004
* Overall rating:
* (5 star) *****
* Overall score: 35.52 out of 37
* Pedestrian rating:
* (2 star) **
* Airbags: Dual front + side + head airbags
* Engine: 2.5 litre
* Variant: Wagon
* Category: Large/Medium car
* Kerb weight: 1439 kg
* Test vehicles built: Sep 2003 and Feb 2004
* Tested in: Japan
MAGPIE is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2007, 07:12 AM   #7
MAGPIE
MAGPIE's Avatar
Side airbags and head-protecting side curtains and optional on the Omega variant and standard on other variants
Apparently not.
Old 25-06-2007, 07:35 AM   #8
Falcon Freak
Falcon Freak's Avatar
It is surprising that the VE is no better then the VZ. The big increase in weight from VZ to VE was supposedly to allow the VE to meet new ADRs and thus make the VE safer then the VZ. Just another example which shows that the VE is not as good as what the media claims.
FF
Falcon Freak is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2007, 08:29 AM   #9
freaky
freaky's Avatar
The holden boys will tell you that ANCAP is nonsense and the VE is built for real world scenarios.
Well, thats was the general vibe on LS1 :
That may be the case, but ANCAP is the only was to compare different vehicles under the same conditions.
freaky is offline   Reply With Quote Multi-Quote with this Post
