Old 30-06-2007, 07:48 PM   #1
20focus05
I wanna XR5
20focus05's Avatar
Default LSD for Focus?
Is there a LSD for the manual LS focus?
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 01:54 PM   #2
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
I don't see why not, but I haven't seen any around.
You could use the phantom grip LSD kit, but they are known of blowing the gearbox casing.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 08:42 PM   #3
BlackLS
Posts: n/a
I've often thought this myself. Though LSD and FWD aren't the best things to mix, unless you like lauching in straight lines a lot.
There isn't one from the factory, but i think the Mazdaspeed 6speed box could have it? Otherwise what extremist said
Old 01-07-2007, 09:25 PM   #4
photn
AFF Post NAZI
photn's Avatar
what gearbox are you guys running?
cause i know there is a Quaife one for the IB5.....just not sure what you guys use. they also assist in cornering....
Old 01-07-2007, 09:59 PM   #5
FOCUSonTHIS
FOCUSonTHIS's Avatar
Quaife make LSD for the LR Focus so I'm sure that they would make a LSD for the LS Focus....should do a search on the Quaife website
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
FOCUSonTHIS is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2007, 11:33 AM   #6
BlackLS
Posts: n/a
We use the MTX75 I think. Same as the LR
Old 02-07-2007, 02:13 PM   #7
melbzetec
Old enough to know better
melbzetec's Avatar
If that's the case, you have the choice of the Quaife, or the Torsen
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
