Old 29-07-2007, 03:43 PM   #1
T3rminator
T3rminator's Avatar
Default What makes a car Service?
Can someone (preferably who works as a mechanic that does servicing) tell me what are the activities that make up a service?
I remember ringing a Ford dealership once to tell them i wanted to bring the car in for a service. I asked them not to change the engine oil as I do that myself. The bloke at the other end asked me "well what do you want us to service then if you have changed the oil". I was very surprised as I thought they would normally do safety checks, and wear & tear (clutch, brakes etc) inspections?
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 03:49 PM   #2
savagE
Complete ****** n bogan
Typically they just change oil, oil filter, air cleaner, plugs, leads. But even Leads and air cleaner aren't that regular.
savagE is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 04:33 PM   #3
The Yeti
The Yeti's Avatar
hmmm a service is preventative manitiance or at leaset thats what its suposed to be, what you are discribing about is a lube at best,
Manufacturers do a lot of reasurch in to what needs to be done of the life of a vehicle and this is broken down in to peridodic services open your log book and look, some services are nothing more than a lube and safety check whilst others involve Transmissing oil change and band adjustment, timing belt replacment etc honastly any one that things a service is just an oil change really hant got a clue
having said that and having worked in a dealer ship I can tell you that most dealer ship serivces tick every box in your log book but dont do much mre than an oil change if that
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 07:10 PM   #4
asusdragon
BA Falcon XT
asusdragon's Avatar
oil and filter that bout it, nothing agianst any mechanics here but i dont trust them, have had few to many bad experiences with them, the one my GF get her car done at does all the lube and filter and pretty much everything else too like last time that did the rear bearing and somehing else to cant remeber. also they do a safety check too.
Click here to check out my signature
http://i238.photobucket.com/albums/f...ignature-1.jpg
If you can't fix it with a hammer. you're got an electrical problem
You only need two tools in life - WD40 and Duct Tape. If it doesn't move and should, use the WD40, If it shouldnt move and does, use the duct tape
asusdragon is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 07:45 PM   #5
macca13
My first job was servicing cars at a dealership. Oil and filter change, check fluid levels, lube hinges, check brakes, wheel bearings and suspension, engine and tranny mounts, check tyre wear to see what the wheel alignment is like. Check drive shafts joints, grease anything with a nipple (not needed on most modern cars), check underneath and engine bay for anything loose or out of place and check lights. Took about an hour.
macca13 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 07:30 AM   #6
red_hotxr6
red_hotxr6's Avatar
I thought they changed the gearbox oil and the diff oil as well?
red_hotxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 10:12 AM   #7
Hunter
Ex EL Falcon
Hunter's Avatar
Well in my experience the accepted form of motor vehicle service these days go something like the following:
1) Customer's car arrives. When customer is out of ear-shot / visual range call the apprentice a fing c word and tell him to bring the customer's car in for a 'service'
2) Apprentice gets into customer's car and revs the bollocks off it, perhaps chirps the wheels and leaves a smudge of rubber.
3) Apprentice drives car onto hoist and then haphazardly (if at all) puts the seat protector in. Leaves greasy fingerprints/handprints on the door handle.
4) Mechanic calls apprentice more foul names and tells him to get to work or he won't sign off on his apprenticeship/punch his lights out
5) Apprentice commences 'service'. Depending on how he feels he may or may not actually replace the filter. If he's feeling lazy he'll just give it a wipe (because removing and refitting is too much work).
6) Apprentice drops sump plug and drains oil.
7) Apprentice goes and gets a container of cheap oil from the back shelf.
8) Apprentice uses air tool to do up sump plug thus rendering future removal almost impossible.
9) Apprentice fills car with said cheap oil and spills a little on the engine.
10) Apprentice makes sure car still runs. If so drive it back down off the hoist, do another chirpie and leave it in the car park for customer's return.
11) Customer returns and mechanic fleeces customer for whatever he thinks he will be prepared to pay. Add random line items to invoice and tell customer that some expensive and difficult to remove item will need replacing soon and that if he doesn't want his kids to die in a fireball he should replace it immediately (and at great cost).
The End. Your mileage/experience may vary. I personally don't use mechanics anymore.
Our Lady of Blessed Acceleration, don't fail us now!
Hunter is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 12:48 PM   #8
sleekism
1999 Ford Fairmont Ghia
sleekism's Avatar
Very true indeed!
My experience with Ford service department went like this:
1)Show up early just in time to watch apprentices show up in VL's and Lancers revving the crap out of cars.
2)Pick car up and pay ridiculous bill for what is simply an oil change and given a list of extra things they did like changing lightbulbs etc and given a list of things that need changing like brakes (which I got the dealer I bought it off to change about a week ago). Find my fuel is down a quarter of a tank and there is mud inside the car as well as maccas wrappers.
3)Next morning I check fluid level and find that not is the oil still dirty but it is WAAAAY over the full mark. Looking underneath car I find that my sump plug has been rounded out. Theory is that some idiot must have undone it the wrong way farked it and decided to just pour some oil into the top overfilling it.
4)Find that bulbs that were supposedly changed are still out, their laser wheel allignment was crap and they failed to note some obvious problems on reprt like degraded coolant.
I have mates who are apprentice mechanics and the service department flogs your cars, rarely do anything and overcharge. What is worst as the people I know who work for Ford are diehard Holden supporters and treat all Fords like shite.
My mum complained for ages that her XR6 had a funny knock in the rear suspension but the bastards waited until the warranty ran out before they told her there was a problem.
them and do your own maintenance or find a good mechanic.
sleekism is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 02:33 PM   #9
T3rminator
T3rminator's Avatar
So would it be fair to say it would be more worthwhile to spend $75 getting a RACV inspection for wear and tear say every 1-2 years, rather than relying on service departments to assess?
Old 30-07-2007, 03:07 PM   #10
chippa
XFT Tuned
chippa's Avatar
two hardest things to find:
1. Good mech
2. Good panelbeater spraypainter..
I'm one of the lucky ones brother in law is ford trained + works in his dads performance shop of 20 odd years and is authorised ford servicer so my XR6T will never see a dodgy service
BF MK1 XR6T,EGO,6SPD AUTO,PREM SOUND,REV SENSORS,DSC,SIDE AIR
315 RwKw tuned by the best in the West
chippa is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 03:08 PM   #11
Hunter
Ex EL Falcon
Hunter's Avatar
Yep. I know in QLD at least that the RACQ does the inspection and you could consider it fairly impartial as they don't do repairs and they have nothing to lose or gain by telling you the truth. Even though they could make an incorrect diagnosis I'd much rather trust the opinion of an experienced RACQ inspector than some greasy sleaze bag mechanic looking to rip me off.
Old 30-07-2007, 04:19 PM   #12
macca13
All I can say is that you guys need to find better workshops and even though I do my own servicing I still put the car on a hoist every now and then to have a good look and check over, and yes I have been bitten by dealer services on new cars luckily the dealerships service reception area overlooked the workshop, it's amazing how much more care is taken when they know you are watching or that you check the car as soon as you get the keys and come back to question them.
Old 30-07-2007, 04:33 PM   #13
Full Noise
Life begins at 40
Full Noise's Avatar
Location: Melbourne. Socialist capital of Victoriastan.
Make sure that other fluids like the windscreen washer reservoir are full before the vehicle goes in for a service, as they tend to top these up and look forward to seeing your face when you receive the bill and find that they charged you $15 for 30 mls of dishwashing liquid and 300mls of water.
Little things like this can help prevent an assault charge when you jump the desk explaining to the service manager how wrong this is with your hands around his throat.
Marriage is like a deck of cards. In the beginning you’ll have hearts and diamonds. Towards the end, you’ll be looking for a club and a spade.
Justice is what you get when you run out of money.
Full Noise is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 04:36 PM   #14
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
No, that's pretty much spot on.
It's funny how it is almost accepted as the norm that you will get shafted when getting a service.
Geeze, looking back at my recipts while my car was under warranty I must have been nuts.
I moved area and used a new service place. I would make bets with my partner as to how soon my phone would ring with the bad news that my car was close to imploding.
They get you either way. If you tell them that you want a call before they do any "extra" work then they load up the bill with oil additives.
Funny how that isn't mentioned on the service leaflet......
Old 30-07-2007, 10:36 PM   #15
Van D
Van D's Avatar
What I don't get is, how the hell are most mechanics in the lower wage category? A friend of mine took her Corolla to Midas and got brakes done.. A new pair of brake pads, some fluid and an oil/filter change later, she was out of pocket $850!!
Originally Posted by irlewy86
Holden made the decision to make thier utes for pretty boys years ago. Wannabe tradesman drive them. If my son came home and told me he bought a holden ute I would struggle to come to grips with the fact he is a homosexual.
Van D is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 11:04 PM   #16
nb_351
building the xe...
nb_351's Avatar
i tell you what you should come somewhere like our work...
if i did something like mentioned, i would shoot myself, let alone what anyone else would do if they found out...
i actually take pride in my work, and used to work at a certain huge dealership, and it was a lot like you all mentioned, change the oil and filter, and unless something bites you with obviousness, it doesnt need doing... do it as cheaply as possible...
i now work at a tyre shop doing all the mechanical work... basically if i dont produce quality work, i dont have a job, and if i dont have a job, i have no xe, house etc...
i believe in being honest, and actually showing the customer whats wrong, if anything...
and then showing the replaced part and explaining it all... and only charge cost price plus 10%
but thats just the way i do it, youll never know unless you find the right place... i nnow theres many more out there, but theres too many shonkies out there...
slowly but surely fixing up the king of the road
WANTED
P5 ltd/landau taillight centre panel
nb_351 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 11:08 PM   #17
nb_351
building the xe...
nb_351's Avatar
for that work, say the pads cost $60, 4 litres of oil, a $10 filter and some brake fluid, would cost ano more than 200, including labour through us...
its something with women, they think they can take advantage of them and charge through the roof, tell them they needed new flux capacitators and they needed a rebuilt hubcap...
add 400 on the bill and they just had a weekend at the races...
WANTED
Old 30-07-2007, 11:09 PM   #18
Hunter
Ex EL Falcon
Hunter's Avatar
No no mechanics are very well compensated for the efforts of their apprentices... or at least the workshop itself is. That's why they love apprentices so much - they pay them bugger all and treat them like dirt. I don't know what they earn nowadays but several years ago an apprentice could expect something like $150 a week for their efforts and no doubt the mechanics make a lot more than that in a given week.
People like you are rare these days dude... Simply finding a shop that will actually do a proper wheel alignment (one of the few things I have to visit a shop for) is really quite painful.
I still remember the time my father took his Commodore to a suspension shop to get the front swaybar bushes done... the knobheads put the bushes in without lubing them up and well they failed about 1-2 months later. They reluctantly repaired them but even so, how bloody hard is it to just put lube on when its required?
Old 30-07-2007, 11:16 PM   #19
Kryton
Kryton's Avatar
my next (first service with the BA) is at Ford only because i want to make sure there are no fault codes, it has the latest flash doesnt have any outstanding recalls and to give them 1 last final chance.
even though i am (in their own words) the "most difficult customer they have", they have gone beyond the call of duty on the odd occasion and done the right thing. thats not to say they havent done the complete opposite either.
i have no warranty, i have no need for Ford service after this.
Old 30-07-2007, 11:28 PM   #20
nb_351
building the xe...
nb_351's Avatar
the lube comes in the bag with the bushes ffs lol
i did a kb laser today, charged him 250, we did cv shafts, all lower control arm bushes, and rack mount rubbers...
took me less than an hour...
we could have charged him upwards of 500 for it, but the parts only cost us like 150, plus gst and some labour...
the quicker you get it out, the quicker you can start the next job, which was a starting a front end rebuild on a ch valiant ute with a 340...
should be fun...
all in a days work... i love it...
WANTED
Old 30-07-2007, 11:29 PM   #21
nb_351
building the xe...
nb_351's Avatar
they only call you that probably cause you want whats supposed to be done for your money etc...
ford training is odne at the same tafe i went to, just a different room...
WANTED
Old 31-07-2007, 04:22 AM   #22
kpcart
i went into a mechanic place and asked i could get a tune up for my previous car, which had carby. they said there is no such thing as a 'tune up' anymore, and that its a service... and starts at $169 or something, which included crap i didnt want done, like spray glossing tyres etc. all i wanted was an engine tune, so i asked, can i just get an engine tune up, and again he says there is no such think as a tune up. place was MIDAS in MIDLAND,W.A. i dont take my car to mechanics anymore, last time i took a car for a 'service' mechanic ended up charing me $450, and a few days later i found the rocker cover was bolts were loose. am i allowed to post his name too? in midvale and drives a ford ute.
kpcart is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 05:41 AM   #23
mowog
Discovery 4
mowog's Avatar
We had a first year in his first week (and last week) fill an engine with oil. By that I mean he filled it to the rocker cover!
Blue Ranger Wildtrak V6 on the way. Factory Canopy & 140l ARB fuel tank.
Discovery 4 3.0 TDV6 SE. Long range aux tank, Kaymar Rear Bar, 18" Off Road rims.
Lotus Trooper.
Mini Inspired by Goodwood.
mowog is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2007, 06:40 AM   #24
The Yeti
The Yeti's Avatar
Every one bags the mechanic yet almost all the above experances are with a dealer or franchise like midus, ultra tune etc, there are literaly thousands of reperatable mechanics out there but they all get tared wit hthe same brush based on Joe customer having taken there car to said mechanic for their advertised $29 lube geting none of the other work the mechanic recomended done (becasue as we know there jsut rying to rip us off) and then complaining that he did nothing and it still runs like crap.
do some reasurch ask around and if your car needs the work get it done
Pariahs C.C.
