Closed Thread
Old 21-03-2008, 12:57 PM   #1
chubbyba
1tuphute
chubbyba's Avatar
Default need help guys, icc.
hi guys i no this is the wrong place but i kinda need help asap. im changing all the speakers in the car, and i need 2 take of the icc for amp reasons.
is it just the 4bolts and 1screw, then the 4 wire plugs to take off?
it seems pretty jammed
thanx guys, so 4 being in the wrong area
chubbyba is offline
Old 21-03-2008, 01:12 PM   #2
chubbyba
1tuphute
chubbyba's Avatar
sorry guys i worked it out, can some one delete this thread,
sorry again guys
chubbyba is offline
Old 21-03-2008, 01:13 PM   #3
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
OK - there are the 4 bolts (2 left and 2 right) There is the screw at the top under the cover.
You by now would realise there is also a need to take off the side panels that cover the bolts.
I dont know if you realise but you also need to remove the lower compartment (just infront of the shifter) there are two screws either side, two pointng down, two going into the dash. Once that is gone, there are the 4 BEM plugs that have little clips on them.
Once you have all that undone hold it at the top and bottom and pull it towards you and lift it slightly at the same time. It should come out - there is a plug at the back that is hard mounted both on the car and the ICC it slots in as the unit is seated.
Remember to keep the unit upright as apparently tipping the unit upsets it somehow.
Just a few.
TURBOTAXI is offline
Closed Thread
