Old 17-07-2005, 08:31 AM   #1
MISTA FIESTA
Da Shifty One
MISTA FIESTA's Avatar
Question Driving an auto like a manual??
Howdy,
Might be a stipid question, but is there any harm to the gearbox in upshifting and downshifting in an auto excessivly, ie 1,2,D or D,2,1 like a manual??
By Excessively i dont mean bang bang bang just a smooth gear change up and smooth gear change down when going into ver very very tight corners ( ie bluemountains) :the_finge
Damian
2013 Ford Fiesta ST - Frozen White - AU 0072/XXXX
- Mountune ST180 Intake Hose - Mountune Quick Shifter - J1 ST180 MAF Adapter - K&N Apollo CAI - Triple R Front Splitter - Richbrook Shorty Aerial - DMB Gel Overlays - LED Interior Bulb Upgrade -
MISTA FIESTA is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2005, 11:41 AM   #2
b2tf
not here much anymore
b2tf's Avatar
Friend killed numerous gearboxes doing this, but he was very rough with them and it was a Commodore.
I think if you look after it and be gentle with it, it should be ok.
2024 F150 XLT
Old 17-07-2005, 02:38 PM   #3
xurbanx
xurbanx's Avatar
lol i know nothing about them .. dad says its when your going uphill and it hasnt got much power .. also under the gear for auto theres that overdrive thing =) dad pushed it on the freeway once on mums focus and it sounded like it was revving higher .. dont know what they do tho
btw ... what does the 1 and 2 mean?
xurbanx is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2005, 03:42 PM   #4
MITCHAY
My mate does it in his VX. I told him your not supposed to do it and his reply was "Why does it have 1,2,3,D and drive for then?" "Its used for inclines, declines, and towing fool" is what i said to him. I cant see it doin much harm if not done very often but wouldnt do it as common practise. I really dont see why he does it as ive done it once or twice in my mums VT and it isnt exactly smooth changing.
With a smaller car if you do it gently it should be alright if used in the way you explained but if you want to drive it in that way perhaps a manual would have been the better choice?
MITCHAY is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2005, 03:49 PM   #5
MISTA FIESTA
Da Shifty One
Yes i am kicking my self now saying i should have got a manual, but ive got an an auto so ill just deal with it.
I only was shifting becasue of inclines, declines not on straight roads if u know what i mean, but my speeds were averaging between 60 - 80 down the mountains.
Old 17-07-2005, 04:02 PM   #6
MITCHAY
Yeah then you are using it in the proper way so thats alright my mum does it in the commy. But i dunno why people use it that way in the city. The whole idea of an auto is so you dont change gears lol. I think ill always go manual or at least tiptronic which isnt exactly an option in every car.
Old 17-07-2005, 04:13 PM   #7
Casper
Contributing Member
Casper's Avatar
Used for upshifts it will do no harm at all (hitting the limiter excluded). For downshifts it can shock the auto as you cant match the revs on a downshift so the auto takes the brunt of the shock. In small amounts it doesnt do any real damage but an "all day every day" situation will hurt the auto.
Using it to stay in a gear and not let it upshift (such as coming down a hill and locking it in 2nd) will not hurt it either.
Older, wiser, poorer.
Old 17-07-2005, 07:45 PM   #8
Steffo
LPG > You
Steffo's Avatar
All the numbers mean is the maximum amount of gears you're allowing the transmission to use. Lets say you have a four speed automatic, so your shift pattern looks something like this:
P
R
N
D
3
2
1
If you put it in Drive, means its allowed to use all four gears. Put it in 2, it can use first and second. Three is first, second and third. Don't think for a second that putting it in, say, 2nd means its always in second. It just means it won't go above second gear, it'll still use first and second.
LPG Lovers Association President & Member #1.
Steffo is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2005, 07:52 PM   #9
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
it's the only way I can drive my auto ZC
it has a full manual valve body
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2005, 11:18 PM   #10
xurbanx
xurbanx's Avatar
whats a full manual valve body?
Old 19-07-2005, 09:51 PM   #11
Amazer
I wouldn't do it all the time and harshly.
The overdrive button stops it using top gear. This should be used around town and is good to have this switched off when under 80km/h. What happens in for example 4 speed Auto as soon as you get to about 40km/h and lift off the throttle they drop in to top gear then as soon as you touch the accelerator it kicks backwards and forwards meaning its continually changing for not necessary.
I personally leave overdrive off around town when in the mood I pull back to 2nd under brakes, when I get the feeling I really wish to be in a manual right now.
I don't own an auto and plan never to, but part of my job means I have to drive them a fair bit.
Rob
Amazer is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2005, 09:59 PM   #12
whippet_zetec
Supes
whippet_zetec's Avatar
guess that the point isnt it Rob, if you want to drive like a manual get one instead of pretending with an auto box
Yes I DO drive a Toyota
whippet_zetec is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2005, 09:16 PM   #13
Danny
GT4.
Danny's Avatar
P
R
N
D
3
2
1
Has anyone ever spoken to one of those people with autos that know nothing about cars??
They all seem to think that to drag, they MUST have the auto in 1st becasue Drive starts off in 4th and doesnt allow for a good takeoff..
The always usually stare at you in disbeleif when you tell them that Having it in Drive and one is the same thing as Drive starts off in first as well.....
Danny is offline   Reply With Quote Multi-Quote with this Post
