Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
#31 | |||
The car felt really strong at the top of 1st and through 2nd. I "sort of" backed off at 3/4 track and braked a bit early to try an avoid getting booted but was not lucky... I've run a best of 1.78 on the Maxxis but now can avarage low to mif 1.8X 60's. I was told that the car sounded like it was spinning in 1st and 2nd and then hooked up in 3rd. I was also told that the burnout was too big? Apparently you only need to turn the tyres a bit to clean them and get a little bit of heat. If they get too hot they do not work as good? I'll put the extractors/exhaust manifold on, fix the wastegate (leaking too much needs a heavier spring, I think) and then get out there again. It's all good fun !!
_________________________________________ |
#32 | |||
I've done 1.54 60' times on a fresh set of MTs 275/40/17s that was when I first ran a 10sec pass (10.89s) Should be intersting to see how you go with your tyre comparison... with 500+ to the wheels. Maybe you might want to turn it down a little ? I've been pretty impressed with the $200 odd dollar Maxxis. Like all tires they are a bit ordinary when they are cold but seem to come on good when you get a bit of heat into them. I've still got some rubber left on the Maxxis and will try and get out there again and aim for a 10. I know the car can run a 10 sec pass on some decent semi slicks but to do this on a ordinary street tyre is my personal goal. Then I can say that the taxi s a real 10sec street car, full weight, full tank of 98, spare, 1900+ kgs on a daily tune!!
#33 | |||
and i hope you get there,but it was a good run you did before though, it will take a bit to beat, but if not, the r888's are a proper legal road tyre, and there are others, that are about as good, and it will be a real 10sec street car it does not have to be cheap tyres to make it real. David
BA xr6turbo auto stock internals(valve springs changed), 10.95 @ 124.6mph street trim stock auto with 2500rpm stall, full wieght, on street radials. 9.94 @137.4mph race trim still standed Ba internals. (race fuel this time) 9.43 @ 146.38 mph built motor. flying the flag in North Queensland. |
#34 | |||
I miss my wheelbarrow
![]() Join Date: Jan 2005
Daniel |
#35 | |||
Here are a couple runs on the 19" Maxxis. (Not the 11.15 & 11.18 sec passes). 11.3 sec pass on the 19" Maxxis 11.6 sec pass on the 19" Maxxis I'm going to try some federal 19" tyres. I've been told that they are pretty good for a low price tyre and I just cant justify $900 a corner when at the end of the day they are going to go up in smoke!!
