Old 07-09-2005, 11:33 PM   #1
EvilChief
Boost Addict
Default a few questions for the Ts ....
ok questions are:
ignition: coil pack or dizzy? if coil on-plug or remote?
head: cast or alloy?
AFM or MAP?
injector size?
throttle body size?
engine gridle: yes or no?
Mic
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 12:22 AM   #2
JC
Miami Pilot
JC's Avatar
Yep, I can see the questions, but what are they in relation to? A T series V8? If so, which model (1, 2 or 3). Or are you talking a Turbo I6?
Ford Performance Club ACT
Old 08-09-2005, 01:08 AM   #3
Steve_T
In aufalcon forum it'd have to be T-series. I don't have one but will try to answer...
Ignition: remote coil packs.
Head: cast on all 200 motors, alloy on all 220s and 250s IIRC.
AFM.
Injectors: I think maybe 24lb on all but dunno.
TB size: 65mm on 200s, 70 on 220s I believe - unsure of 250 but maybe 75?? (probably 70).
Engine girdle: Not on 200 or 220s. Yes on 250s.
Someone can no doubt clear up the ones I'm unsure of.
NB. T-series:
200(kw) = AU1 TE and TL.
220(kw) = AU1 TS and I believe all AU2.
250(kw) = 5.6 stroker = all AU3.
Steve.
Steve_T is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 01:38 AM   #4
EvilChief
Boost Addict
excellent thank you
i am just trying to figure out what parts i will need to buy
cheers
mic
N12 Pulsar - sold
Old 08-09-2005, 02:05 AM   #5
12
Silhouette AU1 TS50.
12's Avatar
Ignition: Remote coilpack.
Heads: 200kW = Cast iron.
...........220kW = SVO alloy up untill April 2001, cast iron there after.
...........250kW = All cast iron.
AFM or MAP: MAP.
Injectors: Bosch 24lb (part # 0 280 155 903) on all.
Throttle body size: 200kW = 65mm.
............................220kW = 70mm.
............................250kW = 82mm.
Engine girdle: Only on 5.6 250kW.
Originally Posted by Steve_T
T-series:
Correct.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 07:58 PM   #6
JC
Miami Pilot
JC's Avatar
Actually isn't a MAF sensor, not MAP - the I6s have a MAP (Manifold Absolute Pressure) sensor in the manifold; the V8s have a Mass Air Flow (MAF) meter in the intake tubing.
MAF is 70mm (actually 68, I think) on 185, 200 and 220, 75/80mm on 250.
Old 08-09-2005, 10:38 PM   #7
Steve_T
Yeah, definatley MAF type AFM on all eights. Thanks for the other corrections though 012.
Old 08-09-2005, 11:40 PM   #8
12
12's Avatar
Originally Posted by 012
AFM or MAP: MAP.
: .. Replace P with F.
PIC'S OF MY
T1 TS50.
