Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
13-04-2010, 03:31 PM | #1 | ||
BLUE BLOOD
351ci
c10 std converter ATM full spool bw diff with 4.11 in xf ute with Cal Traks 8 inch wide MT Slick Looking for under 11.5 Qmile How much power will i need? |
13-04-2010, 04:39 PM | #2 | ||
Patience is a virtue
450hp will do it if your car is set up well. Is it full weight? The less weight the less power you need. A forum member has a drag only XF Ute and that weighs about 3200lb with him in it and it runs around 11 flat at that weight N/A
417ci CHI headed XD. Dynamic transmissions C4 Track times 60ft pb 1.365 (24-3-12) 10.173 @ 134.97mph 1/4 6.324 @ 108.93mph 1/8th PB SOLD Last edited by xagsjoe; 13-04-2010 at 04:46 PM. |
14-04-2010, 03:11 PM | #3 | |||
Our Monaro weighs ~3950lbs and has run 12.09 @ 113mph. Our Territory weighs ~5000lbs and has run 11.8@ 116mph. Weight shifted horsepower calculates ~450hp for the Monaro and ~605hp for the Territory. Both of these are in line with the recorded dyno figures for both cars.
2007 Silhouette Territory Turbo Ghia 11.8 seconds @ 116mph Sold and bought back. |
14-04-2010, 03:45 PM | #4 | ||
Our Monaro also has a small stally and street gears and probably weighs a lot more than your car.
With a bigger stally and 4.11s it potentially could run as low as 11.6.
05-05-2010, 11:14 PM | #5 | ||
i have 475hp my best is 10.97@121mph thats in a xy ute 90/10 in front standed rear
no tramp bars on 235 et radial 5200 stall c10 4.3 gears and i spin it to 7300. hope that helps.. |
