Old 08-09-2010, 08:53 PM   #1
Franco Cozzo
Franco Cozzo's Avatar
Default High stall, how does it work?
Hey guys, I'm curious to a high stall, in an automatic car, how does it work? Does that mean the car won't move until it hits 3000 RPM for example? I've barely ever driven an automatic car.
Thanks much.
Old 08-09-2010, 09:45 PM   #2
pks54
Ford Power To The People
pks54's Avatar
Every car (automatic) has a stall converter otherwise the car will stall when not moving. The stall converter will "slip" untill the stall speed is reached where it theoretically will mean no slipping occures. Thus a higher stall converter will make the car rev faster to its stall speed which will mean you are in the sweet spot zone for more horse power and torque. Usually a higher stall will go hand in hand with lower diff gear ratios as you will see modders put on. As you could imagine with a higher stall and normal cruising diff ratios you will be constantly driving (when cruising) in the "slipping" zone of the stall converter.
Hope thank makes sense.
pks54 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2010, 09:57 PM   #3
Windsor220
Now Fordless
Windsor220's Avatar
It will lock up when cruising though if you have a converter with a lock up clutch in it.
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 01:20 AM   #4
mik
mik's Avatar
http://www.youtube.com/watch?v=MvLoX0z9qoY
http://www.youtube.com/watch?v=PKUbo4gzPAU
Old 09-09-2010, 07:32 PM   #5
JACK250
JACK250's Avatar
As far as I understand it still pulls under the rated speed when driving, it just won't pull hard enough to make the car burnout under stall speed if the brake is applied?
JACK250 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2010, 07:57 PM   #6
Matt47569
Matt47569's Avatar
there's a stall speed and a flash speed.. a 3000rpm stally will have a 3000rpm flash speed, which is where the revs will shoot straight too when the foot goes down
stall speed will be somewhere like 2600rpm which is where you can put your foot on the brake and build revs to that point before the tyres begin to spin. believe it varys with how much torque the car has etc
BA mkII futura turbo 330rwkw on 13psi using standard N/A motor, water/methanol injection and rebuilt 4spd
Matt47569 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2010, 09:17 AM   #7
scoupedy
They use a turbine in a fluid filled disc the outside of the converter is attached to the flywheel and the inside turbine to the transmission as the converter spins the oil grabbs at the turbine and spins it thus removing the shock of gear changes and getting up to the stall speed. The higher the stall the finer the pitch is on the turbine and hence has to spin faster before it gets enough grip this is how i understand it
scoupedy is offline   Reply With Quote Multi-Quote with this Post
