Old 01-05-2011, 01:59 PM   #31
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Default Re: Share your special trick thread.
Originally Posted by jpd80
If you're talking 2004, I think you mean EF
unless you're Doctor Who and travel in a blue box.....
Did you think about this before you bothered typing ?
I bought an EL in 2004 it was built in 1998 if you cant understand that then you need to go back to pre-school...
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2011, 08:10 PM   #32
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
I did this on the old Datto when trying to get crud out from top tank of the radiator.
Find a decent 2L bottle that has an opening that can fit as snug as possible into the opening of the radiator. I used an orange juice bottle. Some electrical tape around the thread will ensure a snug fit.
Half fill the bottle then jam it into the radiator opening and start the car. Once things get warm the water circulates and you will see the crud circulate into the bottle. Whisk it away and repeat a few times.
Old 06-05-2011, 09:13 PM   #33
ELAUBA
Originally Posted by 2011G6E
A popular trick at the time was, apparently, to take the air cleaner off, run the engine at high revs, and dribble a handful of Ajax powder down the carby...supposed to fix it or at least minimise the problem...
Also known as "Hone in a can"
Originally Posted by shedcoupe
Then there's the 'sealing the little radiator leak' trick by dumping a heap of pepper into it.
Egg and pepper works much better. As the water heats up, the egg 'cooks' and finds/clogs the holes, and the pepper helps if they're a bit big for egg on its own.
ELAUBA is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2011, 09:56 PM   #34
smally289
growing up is optional
smally289's Avatar
'Degassing' a petrol tank so you can weld or cut it with a grinder safely. With the tank out, drained and rinsed with water, connect a hose from the tailpipe of a running car into the filler neck and let it go for 15 to 20 mins. The heat evaporates any liquid and the CO replaces any oxygen that may contain petrol fumes.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2011, 05:56 PM   #35
sanchoXB
sanchoXB's Avatar
If I have a problem with a car I give Dad a call, without fail when he comes round to have a look the problem magically dissapears and I look like a fool because nothing is wrong. And when he leaves the problem comes back.
sanchoXB is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2011, 08:25 PM   #36
Falc'man
You dig, we stick!
Falc'man's Avatar
Originally Posted by fowlerj
Baby Oil is what I always used.
Originally Posted by Powdered Toast Man
I'm pretty sure he said switches, not knobs.
Windex to clean the screen that just had coffee sprayed all over it.
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2011, 09:53 PM   #37
SLO AU XR8
When you have finished working on the car and your hands are covered in grease, oil and god knows what else, Sard wonder spray cleans it off in no time! I learnt this trick from my old man, needless to say, Mum isn't too happy when I've been working on my car/my brothers car!
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2011, 08:42 AM   #38
Revolver
Big Member
Revolver's Avatar
Give the man a prize!
X2
Plus some more for when I read that one!
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing
Rollin' on genuine ELGT wheels.
K&N Filter
/////Alpine Sound.
EBGT Momo Woodgrain Steering Wheel
The Scarlet Fairlane Build Thread
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
PWK Build Thread
1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile.
Revolver is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2011, 10:03 AM   #39
XDV800
Or just good old washing powder, the best easy to come by hand cleaner available at every household. Soap and an abrasive combined = WIN for clean hands after tinkering.
(Mind you i have a supply of Wurth sabesto Hand Cleaner - $40 a tub, lasts for 2- 3 years! The best)
XDV800 is offline   Reply With Quote Multi-Quote with this Post
