As the title suggests I have a grinding noise coming from the left hand rear that only occurs now and then when I turn left, but not when I turn right. It sounds really bad and quiet embarrassing at times.
Has anyone had this issue before and could steer me in the right direction to fault find this problem. Any information would be great thanks.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
When in doubt, GAS IT!!
IRS or Live Axle?
Wheel bearing perhaps. Also check your rear brake pads. If they are down to bugger all then the calliper will be very close to the disc and it wouldn't take much lateral movement for the disc to grind on the calliper if the bearing has a little play in it. Bushbasher
Also check ballpoint hasn't collapsed into rotor
It is live axle. I was thinking wheel bearing also.
Anymore ideas?
Lol just retread it's rear
#6 | |||
Walking with God
Could be the handbrake shoes rubbing. Might need to back the handbrake off a tad.
Sounds silly I know, but I've heard mine rubbing on one side when going round corners. Left rear in the wagon it was. GK
#8 | |||
Was told my handbrake isn't the best either. So I think I need to do a process of elimination
Auto correct going spastic I meant re read the original post
Finally got to root cause this issue. It is the LHR hand brake shoe rubbing on the disc. So I will repair that. Also took my axles out to replace the bearings while I was at it. Found out that they were not packed with grease when replaced previously and some genius used silicon on it as well.
Also low diff oil, as when they took the axle out they didn't replace the loss of fluid. Lucky my diff isn't whining.
