23-10-2011, 02:21 PM | #1 | ||
Where to next??
Has anyone experienced this??
1) After a drive the engine does a shake before it's turned off. Has happened a few times before but the last time it was quite noticeable and felt very wrong. It felt the same as if you were to turn off a manual car by popping the clutch in gear. (It's auto). 2) The volume control behind the wheel. Each single press of the button makes it jump several notches. I pressed - last time and volume went from 13 to 4 on it's own. Pressed the + sign once and it went up to 12. Doesn't happen all the time :( Other times, 1 press moves the volume number 1 digit. Thanks |
23-10-2011, 03:05 PM | #2 | |||
2) I haven't noticed that on mine, if you press the volume buttons it only goes up by one or down by one, I'd get that checked out. |
23-10-2011, 04:11 PM | #3 | ||
Torquer
The shake happens to mine sometimes, maybe 1 in 15 trips.
The volume thing sounds like a sticky button or faulty unit, definitely an issue.
2007 LT Focus TDCi S Bluefin Remap - K&N Apollo CAI - 2.5" Turbo-back Straight Pipe - 24mm Rear Sway bar - LT Zetec Bodykit - Black Projector Head Lights - LED Tail lights - DMB Overlays - Alloy Pedals - Scuff Plates - Sports Gear Knob - LV XR5 Springs - LV XR5 Wheels - Pirelli P-Zero Nero |
23-10-2011, 06:01 PM | #4 | |||
Where to next??
24-10-2011, 08:44 AM | #5 | ||
I had a similar issue with my GT TDI VW Golf, as I understand it can be caused by a few things - the DMF (dual mass flywheel) carbon deposit build up in intake manifold, soft engine mountings. I'm not 100% sure that the Focus is fitted with a DMF either but if it is, it's not uncommon and unless it gets really bad it would probably be classified as normal and acceptable, the intake manifold carbon deposit build up is a distinct possibility especially if the car is fitted with a DPF, it's well documented on the VWWatercooled forum where I used to post and has several threads showing the amount of build up and before and after pics As far as the audio issue goes I agree with others sounds like the buttons must be sticking it probably needs contacts cleaned, if it's still under warranty have the dealer look at it
24-02-2012, 06:46 PM | #6 | |||
Where to next??
Will call the dealer to get that looked at as it could be an expensive fix out of warranty. They need a second go at stopping my boot from flooding as well it seems after the heavy rains.... |
24-02-2012, 06:54 PM | #7 | |||
24-02-2012, 07:07 PM | #8 | |||
Where to next??
Got the car back sparkling clean with 2 litres of water in the boot. Assumed they may have used a pressure washer and just removed the water and left it at that. (Didn't want to ask them incase they thought they were somehow to blame for it). Left the car out a few nights in heavy rain and found another 2 litres in the spare wheel boot. Seems to only enter from the rear drivers side lights. Can't actually see any physical sealing when I got it back the first time... assumed it was under the actual light fitting. Will def be asking more questions the 2nd time around. Volume control... tapping it sometimes works and sometimes doesn't. Either way, it shouldn't happen so i'm glad I have it on video as last time I mentioned it they had a WTF look on their face and told the the buttons work as they should. Cheers |
25-02-2012, 12:08 AM | #9 | ||
Mine has a rough idle, and it shakes the whole car if you hold it at around 1000 RPM in neutral while you're stopped.
It only seems to emerge after 50km of driving and the engine is well warmed up, let it sit there with the aircon on and it gets worse. Another issue I have is with the seat, in the morning, its fine, no issues, on the way home from work it creaks, cracks and makes all sorts of noises while driving it, mainly when you move or change gears, the motion of moving forwards/backwards in the seat makes the noises. Oh, and the aircon sucks massive balls, but its better than my Fiesta, so I think its just a Euro Ford thing. Other than those issues, not much to complain about really, though the Fiesta has held up to the test of time a little better, but its got issues with the window switches falling out of the trims. |
