10-09-2013, 07:27 PM | #1 | ||
Hi, I have just completed my XW GS after 3 year rebuild, the engine is from a 1990 F series. I have rebuilt heads were rebuilt and I am running a Holley 650 square bore. Also HEI distributer. my problem is it idles smooth at 650rpm, as soon as i accelarate engine shakes and vibrates. Once I am at around 1500 it runs smooth again.
I have tried all adjustments on carby, timing and advance are working, tonight I sprayed intake wioth engine start to detect leak no change. Can anyone suggest a cause?? |
10-09-2013, 07:30 PM | #2 | ||
More information, I am running a edelbrock 2122 cam which required me to change firing order to early configuration.
10-09-2013, 07:35 PM | #3 | ||
Sick Puppy
Which harmonic balancer have you got on it?
Is a 5.0 or 5.8? A 1990 F series 5.0 will require a 50oz balancer not a 28oz like early model stuff. |
10-09-2013, 07:44 PM | #4 | ||
Hi, it is a 5.0 litre, I am running the original F series balancer.
10-09-2013, 07:54 PM | #5 | ||
10-09-2013, 08:09 PM | #6 | ||
I am not sure of the origin of the flywheel, It came with engine and houses the twinplate clutch, I did not get the flywheel balanced!
10-09-2013, 11:07 PM | #7 | ||
25-09-2013, 08:28 PM | #8 | ||
flywheel.JPGCan you help me identify the flywheel, the flywheel does not have the billiot typical of 23 and 50 oz wheels. it only has a elongated broaching or groove cutout, I will try to post photo when I work out how.
