Bit of debate raging in the Falcon AU to BF section on FF.
I am going to replace the head gasket (first timer for an AU). Not sure what type to use, getting conflicting advice. Both MLS & Graphite ones have been suggested. So which one dammit? ![]() ![]() |
good question mate, however on my own xr6 the stocker ford head gasget has lasted 230,000 k`s and its still going, when the time comes to replace it ................i will be putting the factory stocker one back on.
Edit: as long as the block deck is clean and in good nick and alloy head is surfaced and in good condition and the job is done properly i would be expecting good mileage out of the same factory gasket. |
Missing a sock...
![]() ![]() Join Date: Mar 2012
Mill the head to make sure it's dead flat, make sure the block is dead true - as in using a stone and kerosene. Block the passages off with kitchen paper towel and change them out regularly while you're doing it.
Good luck!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
I have no idea what gasket was used on the AU2's in the factory, nor do I know if the head has been off this car before.
I have chosen a graphite gasket/kit from Durapro as all the reading I've done suggests the grahpites have a higher tolerance for a head/block surface that is old & likely not to be perfect. The head IS getting shaved, & I am using wet/dry sand paper & a cork block on the engine block, combined with WD 40. I'm not a newcomer to doing head gaskets, it's just I've never done the AU model before. Plus I really love this engine so I'm doing my homework before I don the surgical gloves! |
Use a genuine ford mls head gasket and bolts
3 users like this post: |
Ford parts told me today they no longer do head bolts, have to go aftermarket. Mls head gasket still available.
Would this be a good time to get a reco head and or get oversized valves to bring it up to xr6 hp spec?
Build Thread: BA XR8 with all the goodies. fordforums.com.au/showthread.php?t=11247663 |
Job is done now. Not worried about upgrades, just happy to have the thing running. It actually runs a smidge better now.
I documented the work on my YouTube channel: https://www.youtube.com/playlist?lis...h_9x6GV_omXtRU Give it a watch if you're interested. ![]() XR6 hp offers little more than what I've got already. Short unrestricted intake, 2.5" exhaust right thru, high flow cat', 1 muffler, headers. She'll keep pace with the XR's ! |
