Had the dreaded heat exchanger fail last Friday however it isn't a Falcon.
It failed in a 2011 Modeo TDI. In the diesel Modeo, the heat exchanger is located between the block and the radiator. The car has 38K and was 4 days out of warranty. To there credit, Ford customer service have taken on the case. |
Mopar! But Own F6's..
Had a trans cooler let go on my wifes Astra twin top just out of warranty (few months out) too, they didnt cover it.. Same rubbish hey.
F6 TYPHOON FPV 335 GT |
Flairs - Truckers Delight
Do you mean Mondeo? or Rodeo?
Mondeo,
Pity the fool
Interesting.
I wonder if Ford did a bulk buy on the same rubbish heat exchangers for a whole bunch of different models?
Fords I own or have owned: 1970 XW Falcon GT replica ![]() Proud to buy Australian and support Ford Australia through thick and thin |
#6 | |||
I reckon it's the coolant. Probably becomes acidic as it ages.
The true danger only occurs when you take a potentially dangerous piece of machinery and place it in the hands of the most unpredictable species on the planet. Human behaviour, as history has catalogued, cannot account for what any persons actions may be, especially concerning their love of the motor vehicle. http://www.fireservicecollege.ac.uk ![]() |
Pity the fool
That, and I'm pretty sure these coolers/heat exchangers have glue involved in their construction as opposed to soldering/welding.
[QUOTE=Road_Warrior;5038277]Interesting.
I wonder if Ford did a bulk buy on the same rubbish heat exchangers for a whole bunch of different models?[/ The Mondeo cooler looks nothing like the Falcon one. |
#9 | |||
Tell me if I'm wrong here but why would it be a coolant issue , when hundreds of thousands of cars use basically the same formula . Furthermore how does a car that has done 38k and assuming it has been serviced as per log book have a chance of coolant ageing ?
Wake up and stop putting up with crap its that simple . |
Why when you buy a new or near new car should you even have to consider overcoming a problem ? The reality is you shouldn't have to unless the standard of world class car has dropped . It is no wonder ford have problems and until they get their act together and FIX these dramas there life as an importer won't last long either .
#12 | |||
BEN
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels. 331rwkw. 12.7 sec stock as a rock with a passenger. Now with 620rwhp ready to run the 10 built zf, built tailshaft, corn juice all to come. The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw. |
#13 | ||
bitch lasagne
Glue + high coolant temps by design + coolant turning to acid = death for the heat exchanger/cooler.
#14 | ||
do you know how it failed? was there an external coolant leak, or was it internal and mixed with the oil?
#15 | |||
If the problem is a heat exchanger fault - then why has it only occurred on Ford items in such high numbers, and with different parts manufacturers? That's what I've been asking myself for the past 15 years. We've changed quite a few. Even had an AU111 on it's third radiator & second trans - all changed by Ford, first under warranty, second partial payment, third full customer payment. Each radiator was meant to have been "updated". Maybe it's electrolysis, or a crack. But then why does it seem that the majority are vehicles that have not had a coolant change? Like I said just guessing.
#16 | |||
Plus; unless using high magnification, corrosion of metal could start a crack from weakness and fatigue.
#17 | ||
Ford customer care were on to this rather quickly. Service and communication was very good as was the dealer. They have agreed to cover the cost.
#18 | ||
6 month/5000km later and the exact same thing has reoccurred.
#19 | |||
#20 | ||
Stray current in the coolant and earthing against the block, will eat through aluminium in no time.
#21 | ||
i wonder if any one has ever tested the quality of the coolant/inhibitor that goes into these these things, aluminum is a very **** weak metal when it comes to with standing corrosion/electrolysis attack.
#22 | ||
Hmmm ....i think our 2010 MB XR5 might have this problem as im sure we may be loosing coolant ever so slightly at the moment. Will have to keep a close eye on it from here on in.
#23 | |||
i pulled the cooler out of the bottom tank of my AU radiator when the core failed , and the cooler actually looked decent Qaulity brass, not sure what they use these days. Last edited by mik; 12-11-2014 at 12:09 PM. |
#24 | ||
Very interested to hear if they pay for it given the original repair was ex gratia.
They damn well should particularly given Martin's suggestion that the root cause wasn't fixed. Sent from my GT-I9305 using Tapatalk 2
_ __ __ __ __ __ __ __ _ _____________________ 2010.11 Mondeo Titanium MC Ink Blue Diesel Hatch |
