Old 01-10-2014, 07:14 PM   #31
Olbucko
Olbucko's Avatar
Default Re: Anyone ever tried lowering a trailer?
With all the time and money you are going to have to spend you would be better off going out and buying a new trailer and selling the old one to somebody with a truck!
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
Olbucko is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2014, 07:42 PM   #32
xtremerus
FG XR6T trayback
xtremerus's Avatar
You could replace the drawbar and make a goose-neck one, with 150mm drop.
Haven't got a photo, but that's what mine has.
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2014, 07:48 PM   #33
nstg8a
3..2..1..
nstg8a's Avatar
Trailer mob near work quoted me $600 to build me a ute tub trailer, if I supplied the tub. Il price up what this one will cost to get it to what I want and work out which way to go I think.
Originally Posted by pottery beige View Post
Happy mcgadget meal orphan mcboofhead
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2014, 08:58 PM   #34
Gypzy
FG XR6 Tray back
A canopy on the trailer should weigh it down sufficiently to suit the vehicle! Just a thought!
Gypzy is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2014, 09:16 PM   #35
nstg8a
3..2..1..
nstg8a's Avatar
Lol, what does a canopy weigh?
Old 01-10-2014, 09:24 PM   #36
MR REKLAW
BF XR8 Ute
MR REKLAW's Avatar
Could also fit a different tow ball tong, something that brings the ball up higher, with out compromising its loud capacity.Cheers Geoff.
Cheers Geoff
_____________
HIS
2006 BF MKII XR8 Ute,Shockwave Blue.
HERS New One Coming
Past Rides:- XD Panel Van,XE Panel van,XF Wagon,ED Wagon,BA Fairmont,LX Focus
Greetings Earthlings.
MR REKLAW is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2014, 09:32 PM   #37
Gypzy
FG XR6 Tray back
At a guess, 150kg for an ABS canopy. Got an FG tub lying around in the other back paddock too, in Nitro blue i think they call it. I put a tray on the FG, instead of borrowing Dads trailer all the time.
Old 01-10-2014, 09:50 PM   #38
GREGL
Have just been through the same dramas. Trailer 150 mm to high, first step new hitch , managed to gain 50mm , from there I researched tyre profiles, might gain an inch there for a $500 outlay, I then had a brainwave lovells lowerering blocks $ 120 a pair which would have got me close considering the clearances involved. In the end I just bought another vehicle to tow it,
I was borderline with towball download anyway so it was more peace of mind for me. Someone mentioned reversing the hitch to the underside of the drawbar, a big no to that one legally I think you will find
GREGL is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2014, 09:55 PM   #39
naddis01
naddis01's Avatar
When I had a ute tub trailer I had a tow ball with a tall base. It was probably about 50mm taller than a standard ball. If you were nearby you could have it.
So if you got one of them and changed the hitch to the bottom of the draw bar you would gain around 125mm with very little cost. No buying a new drop axle or springs.
Just be careful if you lower the tub itself too much as you can take the front corner out when you go through a gutter into a driveway or something.
naddis01 is online now   Reply With Quote Multi-Quote with this Post
Old 01-10-2014, 10:08 PM   #40
nstg8a
3..2..1..
nstg8a's Avatar
Yeah I think I'm gonna grab one of the adjustable tow hitches, for a little over $100 it at least gets it usable until I decide if I modify this one, or just get a new frame built to my specs.
Old 01-10-2014, 10:14 PM   #41
towtaltowing
theres no way there 150kg there like 50 to 70 at the most ..
towtaltowing is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2014, 10:23 PM   #42
nstg8a
3..2..1..
nstg8a's Avatar
Next time one comes through work il try and remember to chuck it on the scales
Old 02-10-2014, 02:09 AM   #43
mechanic
I've just put a canopy on and off my BF ute TWICE and although I didn't weigh it I'd go along with the 50 - 70 kgs. Mine has a support frame inside for the roof rack and may be a bit more.
mechanic is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2014, 05:08 AM   #44
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
As suggested lowering blocks and longer "u" bolts might be the easiest and most convenient option - dunno if it's legal though. Definitely not legal on a car/ute.
Seems your trailer is rather heavy duty with having air shocks on it, like you said - way over engineered. Can you do away with the air shocks at all or fit just standard shocks? or better still do away with shocks at all? Does it have it's own braking system?
As said before, non braking system reduces your tow capacity to around 750kg - do you need it?
Cheers!
Edit: I've got a 1 tonne ute and I've had the front tyres swimming at times, we all fracture the rules every now and then!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2014, 08:50 PM   #45
XR Martin
XR Martin's Avatar
How about trying something like this?
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 04-12-2014, 10:33 AM   #46
snowcone
Taller towballs tend to snap off.
Forget about fiddling with the trailer as there isn't much clearance underneath and just change your towbar tongue to a stepped up one.
snowcone is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2014, 11:31 AM   #47
Matty4
Banana
Matty4's Avatar
Random I know...
Basically I bought a trailer that sat a little higher than my car, which made the trailer sit on a bit of an angle when towing...
Obviously when it's fully loaded it would sit a bit lower, but I'm doubting it would sit level even then.
Now I've compounded the issue by lowering the car... So I figure I need to lower the trailer to match.
But this pic shows the difference now with the trailer sitting level.
As you can see, the trailer needs to come down a fair way lol
Trailer has leaf springs and air shocks, as far as I can tell there's no air in the shocks.
I was thinking either flipping, or removing a spring, or finding some sort of lowering block? Any issues with either (or both) of these options?
How are you going to fit an adjustable height hitch when it looks like you only have a 1600kg rated flat tongue towbar?
You'll need a whole new towbar with a 50mm box opening to fit that hitch into.
2024 Ford Ranger Wildtrak V6 w/PP
2012 WK2 Jeep Grand Cherokee Overland CRD
Matty4 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2014, 10:16 PM   #48
mik
mik's Avatar
caravan drop axle anyone ?
http://www.ebay.com.au/itm/TRAILER-D...item27cbcf1f5e
Old 05-12-2014, 05:44 PM   #49
nstg8a
3..2..1..
nstg8a's Avatar
Towbar is a 40mm removable hitch, same design as Haymen Reece style 50mm ones.
But your right, the adjustable height one I bought didn't fit. But I did find a 40mm one on eBay that gave a 100mm drop or 70mm lift, depending which way you use it,, so I bought that.
Made enough of a difference that it stopped it looking like the drawbar was dragging on the ground but still needs to be better.
But my fairlane copped it in the hail last week so I'm looking at my options now. May just replace it.
Old 05-12-2014, 05:47 PM   #50
nstg8a
3..2..1..
nstg8a's Avatar
Originally Posted by mik View Post
This was one of the options I was considering.would get expensive reasonably quickly.
Old 05-12-2014, 09:12 PM   #51
GCRXR6
GCRXR6's Avatar
WTF? NO WAY .... Sorry... That is sshhhhheeeesshh.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better!
GCRXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2014, 09:15 PM   #52
nstg8a
3..2..1..
nstg8a's Avatar
Yeah you would hope that trailer has very good brakes.
Old 05-12-2014, 11:40 PM   #53
hootar
The cheapest, best option IMO is to lower the coupling on ya draw bar on the trailer. Either weld the plate underneath or fit a RHS spacer and lower it a bit more if needed. A bit of plate and an hr with a grinder and welder tops and she will be at the right height. You could even buy a smaller basic coupling as it looks like there is no brakes fitted anyway.
hootar is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2014, 02:14 PM   #54
my_gxl
Unintended Perfectionist
my_gxl's Avatar
The one I built was higher than yours, but I used the ute chassis and springs, just made a drawbar for it.
The guy that bought it wanted it for an off road trailer behind a 4WD, so it was perfect for him.
my_gxl is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2014, 03:49 PM   #55
The Yeti
The Yeti's Avatar
Pull a leaf or 3 out of each pack
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
