Old 06-08-2015, 07:28 PM   #1
mcfly94
mcfly94's Avatar
Default Fairlane fixes, direction required!
Hi guys, this stuff applies to fairlanes only.
Couple minor issues i wouldnt mind sorting out.
1 the power antenna wont fully drop into the gaurd, and sits one mast section out.
2 the fairlane high level brake light has some broken light sections in it, and ford want $360 trade for a new one, anyone fixed theres before?
Thanks!
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2015, 08:17 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Fairlane fixes, direction required!
Hi. The mast may have a slight bend in it, other than a new mast you can put the antenna up to full height and then have someone turn off the key and as it goes down you can give it a push. if it goes down past the bend that section may only come up half way and go all the way down in future. With the light you will have to "break" it open to repair it, you may need to change all the LEDs to match colour and brightness levels and dont use supaglue to glue it back together as it may go cloudy like a CSI finger print test. Find a cheap LED brake light on ebay about the same size and adapt it to fit the fairy. Cheers MD
HI
I'M MICHAEL
Old 06-08-2015, 10:39 PM   #3
GasoLane
Former BTIKD
GasoLane's Avatar
Problem #1. have you tried WD40 ?
The one on my old AUII Barge got tired like that WD40 fixed it.
