ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link |
28-08-2016, 03:35 PM | #1 | ||
I have just installed a Colour ICC into my territory it has this extra plug under it is this where the kit plugs into the icc?
Note this is not from my car but the plug looks the same Also the video in for reverse camera can it come from anything that has RCA? or does it have to be NTSC or PAL? i already have a camera installed into a double din under icc be good if it could just plug that one straight into the kit Thanks |
29-08-2016, 11:29 AM | #2 | |||
Sponsor
Yes correct this is where rgb interface kit plugs in, the rgb kit got rca input and it will work as long ur camera is ntsc or pal ntsc switchable Cheers Fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS AUTHORISED FORD REPAIR CENTRE website: www.aslautomedia.com.au email: info@aslautomedia.com AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN |
29-08-2016, 01:33 PM | #3 | ||
Thank you
i think mine is ntsc/pal switchable |
09-09-2016, 02:57 PM | #4 | ||
Hey Fadi i just got around to installing the video conversion kit today
all works except my camera almost seems black and white? except the guide lines are red and green, do you think this is the camera? because on my old headunit it wasnt like this. |
10-09-2016, 12:57 PM | #5 | ||
Its not really black and white its just the colours are very minimal compared the the double din headunit i had , also it seems so bright that it cant really see only up close things are visible i tried turning the brightness down but it still cant see at a distance especially in the sun .
12-09-2016, 08:42 AM | #6 | |||
Sponsor
Could be the camera you are using, we dont have this issue using our camera Cheers fadi75
13-09-2016, 10:48 PM | #7 | ||
Hey it seems someone else was having the same problem with you reverse camera kit using your camera? http://www.fordforums.com.au/vbporta....php?p=5508972
I wonder if this is a problem with the box? |
14-09-2016, 11:58 AM | #8 | |||
Sponsor
This was all related to the camera he was using cheers fadi75
14-09-2016, 02:59 PM | #9 | ||
Ok thanks it seems they do something to the camera to make night time vision better, i have ordered a different one hopefully
it will fix this problem, if not i was wondering if you sell your camera separately to the kit? Thanks |
15-09-2016, 08:54 AM | #10 | |||
Sponsor
Yes we do, see how u go, if you require one please call us 0397991444 cheers fadi75
03-10-2016, 12:35 PM | #11 | ||
I never got around to changing the camera, it looks like the box has died since and I've not got around to looking into a solution yet..
03-10-2016, 01:26 PM | #12 | ||
how long did the video conversion box last?
04-10-2016, 08:46 AM | #13 | |||
Sponsor
best if you call us to figure out the issue pls call 0397991444 cheers fadi75
04-10-2016, 02:30 PM | #14 | ||
Shall do when I get a chance.
Cheers Fadi.. |
