Old 22-03-2010, 06:12 PM   #31
fred43
Hank,
Have mailed you on your gmail.
Ron
fred43 is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2010, 10:23 PM   #32
hankb
Originally Posted by fred43
Probably because it was fitted ion the car when I bought it. It was 12months old an ex company car.
If it were mine Fred I would be ripping the Hornet system out and pelting it in the bin. That's just more electronics to fail, and totally unnecessary.
hankb.
hankb is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2010, 10:45 PM   #33
Mechan1k
Mechan1k's Avatar
BASE on the cluster number means it's a base model cluster ... from memory ... Fairmonts came up with FAIR on them as well.
Mechan1k is online now   Reply With Quote Multi-Quote with this Post
Old 25-03-2010, 04:41 PM   #34
fred43
Hi everyone,
Well the AU is now back on the road.
The problem was exectly as described by hankb.
The BEM had lost contact with the PCM and thats why I had no crank. I had to have 2 ign keys reprogramed to the BEM then the BEM needed a "Parameter Reset" [handshake to the PCM] The parameter reset can only be done with a proper scan tool of course.
This work was done at the local Ford dealer for total cost of $89.
Many thanks to everyone who assisted with this problem.
Interesting thought:- New ignition key from Ford $143 plus $40 for cutting. After sales key from same locksmith including cutting $90.
Both keys work fine.
Ron
Old 25-03-2010, 04:55 PM   #35
gordon_s1942
I just had the battery out of my AU2 for more than 10 days due to doing repairs.
All I did was put the battery back in, connected and cranked it over and it fired.
Reset the radio code and its lost its presets.
I clean forgot all about the Key Code untill I read this.
One thing I have noticed is that it is actualy seems to be more responsive to the acelerator and in Cruise (auto), the shifts are more positive than before.
A friend suggested the computer had wiped all the previously 'learnt' driving information.
If that's correct, all the better.
It always seemed to want to 'Hunt' before then 'surge' off.
gordon_s1942 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2010, 05:12 PM   #36
hankb
Hi everyone,
Ron
Good one Ron...I was pretty confident that would be the problem. You can R & R the battery in these cars with no problems BUT if you are cranking engine and battery craps itself or is almost flat,then the BEM can loose communication with the PCM and hence no crank.
I would have done the job for you only you live a bit far away.
hankb
Old 03-04-2010, 04:42 PM   #37
fred43
A footnote to all this.
Having had the reset done the car ran a little rough for a few days.
Now it has settled down and it is running better than ever. I guess the system has now learnt my driving methods etc.
In view of the way it is performing I cant help but wonder if having to have everything reset wasn't a good thing.
Ron
Old 29-06-2010, 08:35 AM   #38
kelvingregg
So i have a 2000 au amd after an engin change had a bit of fun getting it up and running etc after haveing a falty fuel pump...after fixing fuel pume got it all running sweet exept a broken pipe on power steering rack which i proceded to fix .
After fixing that tryed to start up and got the half cranks then click click clic nothing...now dont get a darn thing all things come on exept no crank..is this also the BEM and PCM... help please as car is stuck at home
kelvingregg is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2010, 12:22 PM   #39
hankb
After the ignition key is turned to the on position does the SMARTSHIELD hand in the instrument cluster extinguish?
Old 19-01-2012, 12:54 PM   #40
NeilS
Default Re: AU Falcon wont start
Hi everyone,
Ron
I have the very same problem with my auii, ive taken your advice and booked into ford to have the keys re-programmed.
Spoke to the master-tech and said it could be a fault with my BEM-Blue?
NeilS is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2013, 07:56 PM   #41
Turton
Somebody must know how to bypass these smart shields
I have heard of a bloke that can twitch a few wires to bypass this bullshit immobiliser
Turton is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2014, 08:33 AM   #42
Ravenon
Raven
Ravenon's Avatar
I'm having a similar problem..My immobiliser light flashes when you turn the ignition on and it won't start..When i leave it on for an hour it goes out then it will start but once turned off it goes to immobiliser mode again
Doin what I do,when I do it
Ravenon is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2016, 12:56 AM   #43
Cherylee92
Default Any suggestions
Hi guys not sure how old this post is but im having trouble with my 99 ford au any tips would be great. It wont start when i put the key in the car doesn't start all the dash lights come on but when i turn the key all that happens is the exclamation symbol.comes on but the park brake is definitely off and it is in park any clue on whats happening?
Cherylee92 is offline   Reply With Quote Multi-Quote with this Post
