Old 28-01-2019, 06:24 PM   #1
Edxr6
Default Au xr8 s3
Fellas,
When I press the lock button on my key fob it will lock all doors except the rear drivers door, this door remains unlocked. Any ideas of the problem.
Regards
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2019, 07:22 PM   #2
deeppocket
Default Re: Au xr8 s3
Originally Posted by Edxr6 View Post
Fellas,
Regards
Bloody back seat drivers.
I Just couldn't help myself
Sent from my Moto G (5) Plus using Tapatalk
deeppocket is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2019, 11:52 PM   #3
snap0964
What happens when you lock by key ?
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2019, 01:22 PM   #4
TICKFORD220
2009 xr turbo,2004 fiesta
Door actuator is stuffed on the door that wont lock.
TICKFORD220 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2019, 04:02 PM   #5
Edxr6
Same situation.
Regards
Old 29-01-2019, 04:03 PM   #6
Edxr6
Same situation.
Regards
Can you buy replacement kits?
Old 29-01-2019, 04:19 PM   #7
GasoLane
Former BTIKD
GasoLane's Avatar
Just type Falcon Au Door Lock Actuator into Evilbay, there's numerous ones to pick from there.
Old 29-01-2019, 10:43 PM   #8
snap0964
A quick thing you can do to confirm this is with that door open, latch the lock with a screwdriver, try lock/unlock.
Old 30-01-2019, 04:37 PM   #9
Edxr6
Old 30-01-2019, 04:40 PM   #10
Edxr6
Not sure what you mean with latch the lock with a screwdriver? Do you mean jamm the lock, if so what will be the result?
Regards
Old 30-01-2019, 05:07 PM   #11
galaxy xr8
Giddy up.
galaxy xr8's Avatar
The screw driver act's as the striker so it thinks the door is closed.
galaxy xr8 is online now   Reply With Quote Multi-Quote with this Post
Old 30-01-2019, 08:32 PM   #12
Edxr6
Cheers OK, I will give this a go.
Regards
Old 30-01-2019, 09:29 PM   #13
snap0964
Yep, make sure it's latched properly - a 'two click action' with a screwdriver.
If it then locks/unlocks okay, the striker needs adjusting.
