Hi all, first visit in so greetings!
I’m having a problem with a 2011 Mondeo with the DCT 450 gearbox. I recently changed oil and took off the valve block cover to clean internal filter magnet to do this I unhooked the electronic feed ( battery disconnected up front) the issue is after buttoning it up I went to start car (in park through whole process) but the vehicle didn’t recognize park position. Tried to shift to neutal and it locked in reverse - disconnecting battery allows me to move to neutral but park position is locked out. Only symptom is the dash reports low battery volts. I have a FIXD scannerbut nothing coming back on the codes so looking for some inspiration - car has not moved or started since work Thanks Jon C |
For additional info - ran the onboard diag. No DTC’s present warning of low battery (12v registered. Have charged and confirmed connections no change anyone help??
Former BTIKD
![]() Join Date: Mar 2005
Tread moved to where it might get more response.
The app usually used on these is Forscan, with a Bluetooth or wireless OBD dongle.
Was there any plugs or cables removed when taking the valve cover off? Sounds like something has gone out of adjustment. When I change the DCT fluid, I just replace the external cartridge filter. Not sure why you would need to take the valve body cover off? Have you checked the levels? Car needs to be completely level and the refilling procedure adhered to.
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢 2008 Peugeot 308 HDi - Highway Hack II 2008 Citroen C4 HDi - Highway Hack III 2010 Peugeot 308 HDi SW - Shaggin Wagon II 2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power ![]() 2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone 2022 Volvo XC40 T4 Inscription - Shopping trolley II 2002 BMW R1150GS |
The only cheap scanner which can show Mondeo TCM data is Forscan.
Next is UCDS I think. |
I had an intermittent sensor code popping so wanted to clean the internal filter magnet off.. I did disconnect the transmission loom during the process so very possible it’s cleared a memory...
External filter was changed and oil level filled but the next step was running vehicle to top levels off which I can’t do because of this issue.. Anyone got a reset procedure / relearn for the gearbox? I’ll have a look for forscan and see if I can get hold of a unit.. not used scanners much so might need a guide.. Thanks for help in advance.. |
#7 | |||
Have you double checked the plug? You didn't damage any pins trying to plug it back in? This may be the issue?? Forscan is available as an app for you smartphone. I found it on the play store and it was around $7 from memory. I use a OBDLink MX via bluetooth but if you use an I-phone you would need the wireless version. I also successfully used a cheaper ebay OBD bluetooth dongle when I first had issues
