Old 23-09-2019, 09:04 PM   #1
cat007
Default Torque app performance test accuracy?
Running Torque app off a WiFi OBD2 dongle.
How accurate are the 0-60mph, 0-100kmh etc tests?
Sent from my LYA-L09 using Tapatalk
cat007 is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2019, 09:41 PM   #2
Falcon SXR8
Falcon SXR8's Avatar
Default Re: Torque app performance test accuracy?
It should be pretty accurate as it gets its speed info from the ecu. Way better than those gps apps you get for your phone anyway. My record for 0-100 is around 3 sec, I'll let you work out how that happened
Had
EB XR8
AU XR8 220 (awsome car )
AU Fairmont
BA MK2 XR6 Turbo
Now
XDUB
Falcon SXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2019, 12:30 AM   #3
cat007
Haha I'm assuming there may have been some tyre slip involved....
My best to date 0-100 is 5.5. Seems a bit slow as I've done a 12.9 at Calder.
Although my speedo reads about 3kmh slow. 100kmh on my dash is actually 103kmh. That shouldn't be that much of a difference though?
Old 24-09-2019, 09:48 AM   #4
ebv8
ebv8's Avatar
i have one called "car performance"
its usually pretty good i only use 1 road for it and cap my speed at 105 as its a 100 zone so basically all legal
i use is when i change something on my car
my AU went from 8.45s to 7.49s and its consistent
it may not be accurate but the numbers it spits out are comparable for my use anyway
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
