29-12-2019, 07:36 PM | #1 | ||
Hey guys just a question, I’ve got a 6cyl fairlane 07 model running on gas, I usually use 10w/40 oils but noticed it’s burning a bit of oil between services so should I go up to a 20/50 weight or is that too heavy, recommendations?
Thanks in advance guys 🍺 |
29-12-2019, 10:16 PM | #3 | ||
Probably tired motor, it’s k’s are unknown but said to be around 200k also runs on gas and have been told gas motors use up the oil more so than petrol, it’s not a lot of oil it’s using really over the 5000k’s service intervals but just wondering if 20/50 would help
29-12-2019, 10:44 PM | #4 | ||
Try the Penrite HPR gas 10w50.
5 users like this post: |
30-12-2019, 12:05 AM | #5 | ||
Or this 20w/60
Had no problems in the ol' 351. Penrite. |
30-12-2019, 12:14 AM | #6 | ||
Don't worry about the first number in Australia (perhaps consider it where it snows)
Try a xx/50 see how you go If it's burning oil due valve seats (smokes on start up) changing grade won't help If it's leaking oil changing grade won't help |
30-12-2019, 08:15 AM | #7 | ||
I found 20w/50 in our '97 EL and FIL's '96 EF would make them idle rough.
Switch back to 15w/40 and the smooth idle would return. Don't know about a Barra though. Have never tried it in ours.
Our FORD Stable 2008 FG GT-E - Lightning Strike 2007 BFII Fairmont Ghia - Seduce 2007 BFII Falcon ES - Ego |
30-12-2019, 08:23 AM | #8 | ||
Cabover nut
I use this myself in the crossy and in the smaller trucks in summer.
Good stuff. Penrite.
30-12-2019, 09:00 AM | #9 | ||
Thanks for that yeh living up nth, no smoke on start up and I’m pretty sure the oil burns from running gas instead of petrol so will see how it goes with the next 5000k using gulf western 20/50, it’s on special atm at Supacheap 👍
30-12-2019, 10:00 AM | #10 | ||
When in doubt, GAS IT!!
LPG won't be the reason it's using oil. I've run LPG falcons for 20 years and not had that issue. We have a 08 bf wagon on gas with 320k on it and it doesn't use oil. My AU Fairlane is approaching 400k and still doesn't burn oil.
Go the Penrite Gas 10.
30-12-2019, 11:37 AM | #11 | ||
200,000km is barely run in for these running LPG.
Hardly say it is tired at all. Unless it has been around the clock and is at 1.2 million kms .... that's a different story then.
30-12-2019, 12:35 PM | #12 | ||
It’ll be fine
Don’t know if it will solve your problem but it won’t hurt the engine
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
30-12-2019, 02:17 PM | #13 | ||
Also by usage of oil I mean it was on the full line on the dip stick when last serviced and 5000k’s later it’s on the half line, normal for gas?? Was a replacement motor said to have done 190,000k’s which is around 200,000 now
30-12-2019, 03:09 PM | #14 | |||
If it’s country miles or hwy miles and long runs that’s probably about right If it’s stop start short runs it’s a little high Realistically it’s not the end of the world and I wouldn’t worry much What’s the intake look like is it wet and oily? If so it’s a bit of a concern
30-12-2019, 03:51 PM | #15 | |||
"also runs on gas and have been told gas motors use up the oil more so than petrol." That's an interesting piece of bullsh*t. What makes you think that changing to a heavier grade of engine oil would reduce oil consumption? Could it possibly be along the lines of................ It's a 'thicker' oil & therefore it won't fit through the clearances as easily. 200,000 kM on a Ford 6 cylinder engine is nothing. It's not necessarilly the kilometres that wear out an engine, it's the amount of abuse & neglect. |
3 users like this post: |
30-12-2019, 05:13 PM | #16 | ||
I did 5000k in 3 months a lot of stop start and heavy driving, some city freeway too though if that tells you anything, intakes all good
30-12-2019, 05:31 PM | #17 | |||
General rule of thumb is around a liter of oil to 2500km, plenty of people will disagree but your going to use oil and with your described driving and oil usage I’d say that’s about right As for gas burning more I’ve played with a lot of gas engines and I’ve never noticed any difference in oil usage I suppose (maybe) as gas is dry when it blows past the rings it won’t be liquid and dilute with the oil but, I highly doubt It would make a noticeable difference FWIW I had a crossflow 6 in an XF once that was that fumey through the PCV I would choke an air filter in a week, I ended up routing the PCV to an old oil bottle so I could use it to top up the engine and so it didn’t cost me a filter element a week
30-12-2019, 05:35 PM | #18 | ||
B1 - J & D Services
I would recommend removing your pcv valve and placing it in a bottle or similar. Then blocking the inlet into the intake. See if the oil consumption slows over a few tanks. I have had three that sucked oil back through the intake in this way.
Mr. Brett Johnstone. 2002 Ford Laser 2000 Ford Falcon Wagon Egas 1999 Subaru Imprezza Sportwagon 1998 Holden Suburban 2500 1995 Land Rover Discovery TDI 1994 XG XR6 Longreach 1983 Holden Rodeo 1975 Datsun 120Y wagon 1970 MG Midget 1967 Rover 2000TC Soon: Model T. |
30-12-2019, 05:36 PM | #19 | ||
That’s awesome thanks for the tech tips much appreciated, it’s a big lug of a thing to throw around the streets so as you said it’s about right works for me cheers
30-12-2019, 05:50 PM | #20 | ||
Cabover nut
Otherwise known as installing a catch can.
30-12-2019, 05:59 PM | #21 | |||
31-12-2019, 02:58 PM | #22 | ||
I ran 20W50 Synthetic in my SY Territory from new. Although I don't own it any more it has now done 340,000 Km. It only uses about 1 litre of oil every 15,000 Km and still runs like new.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
