Old 12-05-2021, 12:23 AM   #1
Edxr6
Default AU Passenger Door
Guys,
I can open my passenger door from the outside but not from the inside. Any ideas what is causing the problem.
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2021, 12:30 AM   #2
Default Re: AU Passenger Door
Check the cable linkage from the inside that runs down to the latch mechanism. So that requires the door card off, but thats not difficult.
Old 12-05-2021, 12:42 AM   #3
The metal rod is what goes to the external handle, the cable is what connects to the internal handle, if that helps. So it could be busted plastic bits on either sides, or if its the rear door, check if the child lock is on. Ive only repaired an au ute, so no rear doors.
