26-12-2021, 11:26 PM | #91 | |||
The main reason im considering a traxxas slash isnt because i hold traxxas in high regards. But parts are cheap and available. Nothing wrong with my maxx, its got all the available telemetry mods fitted, drive train and suspension mods, 6s esc, varios sets of tyres. Its a different kind of fun to what i was used to. So i wont go too far into it but backfliping off the wall off my house left tyre marks on the eave. Im more thinking something but better then the 2wd rustler i had. I bought that thing in 2008 because i had to spend more time at home because my mrs was pregnant. That thing handled ok. The stock brushed motor and esc, yeah, i binned on day 2 for a primitive 3s brushless setup. But if i can find a slash cheap enough, the 3s esc will instantly be replaced with the 4s one i have. I'll probably pair it to my current controller because its got the bluetooth doodle, then go through the motions again of breaking axles and such to regain the title of breakzilla. |
28-12-2021, 06:06 PM | #92 | ||
Well, i found a good deal on a slash within my budget, so the 4x4 brushless one.
Plan is, the 3s esc is instantly gone. I have a perfectly good 4s unit to replace that. Also, gearing, i have a selection of pinions. Tyres probably, but other mods, i shall have to run it before i decide. |
30-12-2021, 03:05 PM | #93 | ||
Barra Turbo > V8
So the battery i have is an 11.1V 3S LiPo.
The battery compartment seems to be confined also. Its not a hard case and was assured that it wont expand when it gets hot (it definitely has) so once run its almost impossible to get it from the compartment. Its pretty well ventilated as well. It has a spacer in there which ive now removed but the battery will move around (probably has 5-6mm play either side and about 10mm above. So im not sure which way i'll go as i dont want to spend a fortune on it as im sort of deciding if i want to buy another car also (perhaps the Losi super baja rey, or a rovan 5iveT) But i still want to enjoy this one now, so i may bite the bullet and buy a cpl of the recommended Spektrum LiPos. (car is full spektrum kit out) and if i buy 2 3s batteries they go in the super rey too (it takes 8s LiPo)
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
30-12-2021, 03:18 PM | #94 | |||
Anyhow, did aftermarket tyres change it up? |
30-12-2021, 03:27 PM | #95 | |||
Barra Turbo > V8
Its an NXE-Power super-nano 5000mAh 3s 40c. Even after charging it and not using it still slightly expanded (not as bad as after a run though) I do normal charge, charging at 5 Amps. Its had about 6 charge cycles since ive had it. From what ive read, this car has a pretty decent current draw, not sure if that would exacerbate the issue. Driving it on a mix of 75/100% throttle also Happy for some tips or if im doing something wrong. Tyres made it totally different, but if i load it up with AVC off it'll balloon the fronts as little but they are much better as theres more tyre on the surface. The standard ones would balloon the rears also.
30-12-2021, 03:48 PM | #96 | |||
Dont take my word for it, look up the Google's or something, but if a lipo bulges you probably shouldnt use it. |
30-12-2021, 03:55 PM | #97 | ||
Barra Turbo > V8
I really havnt looked into the balance bit, perhaps i should. I know what it does, i just didnt do it, rookie error. I reckon after the next run (probably tommorrow) ill do that
30-12-2021, 05:03 PM | #98 | ||
I've always done what I've been told with lipos. So ballance charge at a 1:1 rate. Never had an issue with heat or bulging. Im kind of terrified at how quick they go up in youtube videos of lipo fires.
30-12-2021, 05:14 PM | #99 | |||
Barra Turbo > V8
Ive just started a balance charge on it as we speak. I should have just bought a 2 stroke petrol SCT
30-12-2021, 09:31 PM | #100 | ||
I am Batman
ahh Lipos... the bomb in your hand!
Always balance charge, Safe way is charging at 1c ( I do all mine at 2c), do not drop the cells below 3.3v or 9.9v total for a 3s if possible when being used and always store at 3.8v per cell and try not to leave them fully charged for extended periods. I use to storage charge after 3 days if I didnt use them. High draw in use can kill them and cause them to puff. Slight puff you can get away with but you will see reduced performance and high IR cells. Lipos are no joke and whilst they are a consumable, should be treated as being very volatile.
Rebuilt Boss260 with #Kellogs 1500hp forged and balanced crank#Manley forged flattop pistons with a 9.5/1cr#4340 forged h-beam rods with arp bolts#Clevit performance rod and main bearings#full ARP headstud kit#total seal rings#Mantic twin plate development clutch and lightened flywheel#Mellings uprated oil pump#Mainforce Performance Supercharger kit#AU motorsport 345mm big brake kit. Now sat on an engine stand going nowhere
30-12-2021, 09:34 PM | #101 | |||
Barra Turbo > V8
31-12-2021, 04:25 PM | #102 | ||
Havent received the slash i ordered yet, but i did receive the tyres for it.
So i got the louise turbo tyres for the slash. So a very mild tread pattern. I have my reasons. So my maxx i have louse uphills which are great, but i run louise rocket street tyres. Reason being the maxx is stupid overpowered and over geared so the grippy uphills make it too much to have fun with. Street tyres arent as touchy so yeah they spin, but its more fun not having to be as sensitive on the throttle. So i dunno 100% if the stock 4s esc from my maxx will fit the new slash when it comes in, if it does, the slash should be fast. It wont be as fast as my maxx, but i built the maxx purely because i could. And yeah, my goal was 100kmh in that and it does 131. The slash, my hope is it handles well out the box and I'll be satisfied with 100. I think the slash's are pretty fast anyway as they arent a heavy lumbering oaf like a monster truck. |
31-12-2021, 04:46 PM | #103 | |||
Its an older hpi baja 5b. So stock it was 26cc, the current ones are 23cc high output. His he bought 2nd hand and modified. So it has a bigger piston and cylinder making it 30.5cc and an aftermarket exhaust. It takes a 50:1 mix. The thing is big. It goes alright, but due to the chainsaw style drum centrifugal clutch its a bit doughy off the line. |
31-12-2021, 06:56 PM | #104 | |||
Barra Turbo > V8
I reckon ill get one 4WD though. I didnt want to pay the Losi mark ups. Went and got some rubber and cable ties and made up my own mud flaps. Dont mind the mess in my shed
02-01-2022, 12:44 AM | #105 | ||
Im keen to get the 4x4 slash. It should be in on monday. I say it now, but that will probably change, but I'm not going to go nuts on it. Subtle mods, i already have rims and tyres for it, but nothing like the maxx. That thing is over everything. Overbuilt, stupid fast.
The slash, the plan is fast enough but still be fun, and do corners. So mid 90s to maybe 100. Its going to be different to a monster truck. But, it shouldnt be a bad thing. |
04-01-2022, 02:28 PM | #106 | ||
So my son contacted me yesterday saying he wanted to build a 1/10 drift car. So get a kit and put it together himself. Im all for that, my kid gets a great sense of achievement when he builds something himself.
So i said find the kit you want and ill give the ok if it looks good. So he did his reasearch and the kit looked good. However i didnt ok it, he had to do further reasearch on if replacement parts are available. So the boy is 12, anyhow i agreed to transfer him some money if he gave a cost breakdown. He goes 1000. I laughed and said thats the 2jz 1000. He gets that joke. Any person you meet with a supra or is300 and says theyre going to modify it, when you ask how much power will it make they instantly say 1000. So no, i didnt give him that amount. Today he is super excited. He went down to the hobby shoppe today, didnt get the initial kit he was after but a better one in my view. I wasnt with him, but unless its really silly, i let him make his own decisions. So the kit he was initially after was 2wd. I suggested 4wd. He says he was like a kid in a candy store. So he got himself a team magic 4wd drift car. I did the sneaky and looked up the shop he got it from, and they sell spares for it, so thats good. Its a belt drive so he tells me if he wants to go rwd its as simple as removing the front belt. He is a bit bummed because he had to make a slight compromise. It has an rx7 shell but he wants a 2018 mustang shell. He hasnt blown his budget so he can always get a mustang shell. But hes happy because he didnt have anyone make the decisions for him, he was in charge of the budget (sort of, i gave him the money and he had to work within that) and he got what he decided was the best for his intended use. |
04-01-2022, 07:04 PM | #107 | ||
So i received the traxxas slash this arvo. My suspicions were correct, the 4s esc i have is physically too large to fit. My 4s batteries are also to large for the battery tray. Not the end of the world, 3s batteries are cheap so i ordered a couple.
So yeah, havent given the thing a test rip yet. I have put on aftermarket tyres and longer gearing. For what i paid i reckon they could have atleast done threaded ally shocks. But the dual rate springs i reckon should be alright. Thats it. No plans to go ham on it like my other rc car. |
04-01-2022, 07:10 PM | #108 | ||
Barra Turbo > V8
Not much to report.
Got a matching set of tyres today, reset rear shock mounts to a lower position also. Will se how it goes.
05-01-2022, 05:01 PM | #109 | |||
My kid was onto me today. His drift car build has begun. He is very enthusiastic about it. So the main thing was he wants doesnt want new batteries, so wants an adapter. Getting him to send a non blurry pic was like extracting blood out of a stone. So i ordered him the correct adapter. Anyrate, he sent me a pic of his incomplete build. He is still within his budget, but has aftermarket wheels and tyres on it. So he still has to space the body up so it doesnt scrub on lock. I asked if he will put the big wing on, he wants to be part of the big wang gang. He is happy with his purchace. I asked if he was still going to get a mustang body for it? He has changed his tune, he likes the rx7 body more now. |
05-01-2022, 07:07 PM | #110 | ||
Barra Turbo > V8
Quick bash in the rain today.
As for tyres, im not big into it yet. But i changed tyres purely to stop the ballooning of the standard ones. If they didnt id have kept em, but the new ones provide a lot more grip imo. What they'll wear like i dunno.
07-01-2022, 04:10 PM | #111 | ||
Got the 3s batteries for my slash today. So maiden run lasted maybe 60 seconds. The slipper clutch was too loose and screaming like a banshee. So traction aid, yes but mega slow. So tightened that up and round 2. So it has aftermarket tyres on it and a pinion gear. So it will wheelie off the line but not on comand like my other car thats modified. But it handles as good if not better then i hoped. So at worst at speed cornering hard it will lift a wheel not roll over.
Its deffinately snappy off the line, but not stupid like the 6s powered maxx i have that if not careful will flip onto its lid off the line. Deffinately not as fast in the top end. But all the over the top things i did to the monster truck kind of made running it a chore and took the fun out of it. The short course truck, so far its fun because its nimble and not that fast. |
07-01-2022, 04:17 PM | #112 | |||
09-01-2022, 01:26 PM | #113 | ||
So i was asking my kid if he wanted me to get him lipo batteries for his rc cars. He said no. He has watched too many youtubes of people with mega $ 200+kmh rc cars smash and compromise batteries and burst into flames. Kinda silly as his gear, as is mine, is not that extreme.
So i asked would he like a better charger? He said what one. So his existing charger for his 7 cell 8.4v nimhs isnt a fast charger, its not a slow charger, its an eventually charger. So i ordered him the same does everything charger i have (well the 2nd one, the 1st crapped out after 13 years so i reckon theyre good) an imax 6bac. So considering its a 6A max output, will do nicads, nihms, up to 6s lipo and lead acids, for under $40 i reckon they're a good thing. Before my original one died, and probably part of the reason it did, it had on multiple occasions been left overnight charging 730cca deep cycle marine batteries. |
09-01-2022, 04:37 PM | #114 | |||
I am Batman
My imax was relegated to 18650 and 2s lipo duties. also it wont charge at 6a... its one of the limits of the 50w input. ( depending on battery size iirc, I would have to look the math up as I cant remember it off top of my head) edit: assuminga 3s battery 50w/14.4 = 3.47a... iirc
09-01-2022, 05:37 PM | #115 | ||
I am Batman
doh.. 3s is 12.6v so 50/12.6 = 3.96a
09-01-2022, 05:55 PM | #116 | ||
So 1s is rated at 3.7v. However fully charged is 4.2v. So its simple maths. So 2s is rated at 7.4v but fully charged is 8.4v. 3s is 11.1v but 12.6v full charge.
I run 6s on one car. |
09-01-2022, 09:45 PM | #117 | |||
I am Batman
I do parallel charging, usually 6 x 1300mah 6s batterries at 2c at a time, or 6x 1300mah 4s bricks depending on which quad I fly, so needed something better.
09-01-2022, 09:56 PM | #118 | ||
Im a bit of a wimp when it comes to charging lipos. So 1:1 regardless of 3s, 4s or 6s. Nihms, i used to pump them as hard and fast as possible. But nihms were a long time ago for me, and i keep the boundaries close for lipos.
09-01-2022, 10:05 PM | #119 | ||
I am Batman
general rule of thumb is 1c charge would take about an hour.
As i only get 2-3min tops flight time per battery, I wasnt spending 6 hours charging or longer as Iwould take 10-15 batteries with me to the field, 6 in half hour or so was good enough for me!
09-01-2022, 11:02 PM | #120 | |||
So yeah, charge time is around an hour. But, they get a lot longer run time in an rc car then an aircraft. On 4s i get between 30 or 40 minutes depending for my monster truck. Running it on 6s, its hard to tell. Mainly because its a tad bit too easy to crash. My short course truck. I dont doubt the batteries, but considering its stock with a pinion and tyres on it, on 3s the thing is awesome but for reasons unbeknown to myself, it overheats and says no. |
