07-08-2022, 04:02 PM | #1 | ||
Hi Guys,
What are your thoughts on using UV Dye in the crankcase to find oil leaks on an engine? I've seen some Ebay kits for around 30 dollars that come with the UV light and a bottle of Dye, the instructions are pretty simple...it says add dye to the engine oil, run it and look for leaks using the light. Does it really work and help find niggling oil leaks that are otherwise hard to find visually or is it a gimmick? Cheers, BB
2015 FGX XR6T Ute - Aero Blue - Leather Trim - 6 Speed Manual 1966 Mustang Convertible - Wimbledon White - 289ci Windsor - C4 Auto - Power Hydraulic Roof / Factory AC Previous Fords: - 2012 FGII XR6 Manual Ute - Kinetic - 1984 XF Fairmont Ghia - Olympic Gold - 1987 XF S Pak - White- 1994 ED Falcon Classic V8 - Polynesian Green - 1999 AU1 Falcon S - Hot Chilli Red - 2009 LV Focus Zetec 5sp Manual - Black Sapphire |
07-08-2022, 04:40 PM | #2 | ||
They do work. Only issue I have ever had is most air conditioning systems, power steering systems and some coolants use (or can use) similar dyes so check for other leaks that respond to the UV light before adding the dye to the cooling system.
regards Blue |
4 users like this post: |
07-08-2022, 04:49 PM | #3 | |||
07-08-2022, 07:30 PM | #4 | ||
Thanks Guys...ill give it a going over with a UV light and then chuck some dye in and see what happens.
