Old 16-08-2024, 07:40 AM   #1
Default When: The End of Crank Holes
About when did Australian market cars stop coming equipped with a hole for crank starting, and the handle to accomplish it?
One of the last I can remember was the Renault 12, which ran until the mid-seventies. Looking at pictures of EK Holdens, I can’t discern a hole in the front - but maybe it’s below the bumper, and I don’t believe even the first XK Falcons had a crank hole.
Old 16-08-2024, 07:47 AM   #2
Franco Cozzo
Franco Cozzo's Avatar
Default Re: When: The End of Crank Holes
Reckon they still exist in Melbourne's mens public toilets
Old 16-08-2024, 07:51 AM   #3
That wasn’t what I meant!
Old 16-08-2024, 07:55 AM   #4
Dr Terry
I don't believe that any Holden or Falcon had provision for a crank handle.
It was much more popular pre-WWII when electrics were less reliable.
Dr Terry
Dr Terry is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2024, 08:14 AM   #5
None-ya
For some what some reference I think a E-Series starter MAY bolt to a cross flow but a crossflow starter is NOT interchangeable with the pre-crossflow ( I may be wrong and thinking pre-crossflow to before ( I'm not sure what that motor is called/goes by( Canadian motor I think and had both a electric starter and a hand crank
All people have the right to stupedity but some people abuse the privilege
None-ya is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2024, 08:27 AM   #6
Hulsty
60 series Landcruiser had hand crank provision, though I believe "most" OZ market ones had the larger radiator which obscured the crank nose, they ran to 1990. 40 series Landcruiser also had hand cranks (1984) aswell as a bunch of older cruisers (55 series).
The Silver Bullet - BJ74
Where the actions at Ontrack 4wd Club
https://www.facebook.com/ontrack4wdclub
Hulsty is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2024, 08:36 AM   #7
Tonz
surely with the compression of today's engines it would be impossible to hand crank a motor. think of trying to crank start a 12cyl Lambogini
Old 16-08-2024, 08:49 AM   #8
Good points Hulsty, do you also know if Land Rover carried the crank starting option into Series 3?
Generally, too - didn’t the early Beetles have a crank hole?
Old 16-08-2024, 03:08 PM   #9
Itsme
Experienced Member
Itsme's Avatar
Dr Terry
Definitely Holdens not at all and 1960 Falcons onwards never had any.
Old 16-08-2024, 03:33 PM   #10
Have just checked the early Series 3 Landy in the shop, crank hole in the bumper.
Old 16-08-2024, 03:49 PM   #11
Sprintey
Sprintey's Avatar
2H 60 Series definitely had it.
Surprised to see M&D's Renault 12 had it, but the car was designed for North Africa. Beautiful car, so comfortable front seats, you could rally it on dirt tracks happily, and a really weird (and sensible: north/south fwd means no torque steer) FWD setup. Ours was Virage wagon.
I6 + AWD
Sprintey is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2024, 04:25 PM   #12
Dr Terry
Are there any pre-1960 Falcons around, are there ? Just sayin'
Dr Terry
Old 16-08-2024, 05:23 PM   #13
Itsme
Experienced Member
Itsme's Avatar
Dr Terry
My bad I meant to use the word Ford not Falcon, just sayin'
Old 16-08-2024, 06:20 PM   #14
The last car in our family that I can recall having provision for crank handle was a "Beetle Backed" Phase I Standard Vanguard.
It had the little bit in the middle of the bottom half of the venetian blind style grill that folded down to access it.
Old 16-08-2024, 06:58 PM   #15
mad2
Regular...with metamusal
Dr Terry
nor did any Valiants, local or imported.
Old 16-08-2024, 07:09 PM   #16
gregaust
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Greg always goes out of his way to provide assistance and support to members of AFF. Greg freely shares his knowledge with people who ask for help and often assists them with obtaining parts and repairs.  A great member of the AFF community. Technical Contributor: For members who share their technical expertise. - Issue reason: Always happy to offer assistance from his own experiences and often posts up photos when someone is having issues finding/locating something they are trying to repair or replace.
Only one I ever had was my Dads series 1 1948 land rover
gregaust is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2024, 07:15 PM   #17
Franco Cozzo
If you see this happen, then you cut it mid stream and run
On a more on topic note, imagine trying to hand crank a modern car, 10.5:1 compression ratios, or a turbo diesel in the vicinity of 17.5:1
Old 18-08-2024, 12:05 PM   #18
Originally Posted by Sprintey View Post
…Ours was Virage wagon.
Edit, wrong car and motor/box configuration. But I’m still pretty sure there was no crank start option for the Virage. You could troll Aussieflogs to ask them.They were a five speed, which from memory meant there was no dog on the front of the gearbox due to the overdrive type housing. Probably still a hole below the front grille, though.
