03-08-2013, 10:46 AM | #361 | ||
silkroadsurfer
just chammoised the wet dew off my car . needs a good vaccuming out too because bloody rooflining is sagging bad and the orange fluff is all over the backseat area n parcel shelf . grrr
03-08-2013, 01:44 PM | #364 | ||
Unintended Perfectionist
Watched its location on the vehicle tracker.
Its funny people actually work on your car after you tell them you know it hasn't moved.
BA-FG parts for sale. http://fordforums.com.au/showthread.php?t=11411117 http://s1092.photobucket.com/user/my...?sort=3&page=1 The XR re-erection in the works http://www.fordforums.com.au/showthread.php?t=11386452 |
03-08-2013, 02:39 PM | #365 | ||
Super Happy Fun Slide
Purchased some new front shocks, bloody Ford changing shock design at the end of the BF run, lucky I found out before I purchased them that from Aug 07 to Apr 08 they changed the design.
It is also lucky that the new springs I got were the right ones, thank god the supplier was on the ball and new the changes, he suggested the change was a cost saving one as the new design was a off the shelf item which ended up being a couple of dollars cheaper per unit. Also used my 20c fuel voucher and saved $15. 10.8 litres/100klm around the burbs. Also as I am a sucker for commercialism I got a GRIPGO, my phone fell off it on the way home after buying it...... |
03-08-2013, 03:38 PM | #366 | ||
I got in it and drove it Brunswick Heads...
Windsor...... Clevo...... Boss... and in that order too.. |
04-08-2013, 07:36 AM | #367 | ||
Lacking Imagination
Put some new shoes on the Ol' gal
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
3 users like this post: |
04-08-2013, 09:24 AM | #369 | ||
Lacking Imagination
cause they are too much car for most people
Cheers JET!
05-08-2013, 04:51 PM | #370 | ||
Recieved my private plates yesterday and today I had new seatbelts fitted.
That was a quick $900 spend, worth it tho im super happy
"Clowns may be funny in the circus, but they are killers on the highway". "I didn't get much sleep last night I had a Brazillan woman banging on my door ALL night! - I finally got up to let her out" Click here to see my ute |
05-08-2013, 06:55 PM | #372 | ||
Was yesterday but removed the Crappy weather shields, took a chunk from my finger when one broke while I was yanking on it lol
Sent from my HTC One X using Tapatalk 2 |
05-08-2013, 07:13 PM | #373 | ||
This was yesterday;
Changed engine oil & filter Changed Transmission fluid & Filter Fitted an external transmission cooler and only one small area of skin missing from my wrist, didn't swear either!! |
06-08-2013, 03:45 PM | #375 | ||
06-08-2013, 03:49 PM | #376 | ||
Off smelting
Fitted big mouth and growler airbox.
2008 FG falcon xr8 in nitro, 6 speed manual, Djr bobtail, 20's, growler intake and manta twin 2.5 inch exhaust. |
06-08-2013, 04:53 PM | #377 | ||
Saved the engine!
My son noticed a big trail of oil along the driveway last night so out we go and have a look. Big puddle under the engine on the concrete. I have a donkey light and an oil pressure gauge coming out the side of the block with adaptors and the adaptor going into the block had split! Started pulling it all out this morning and it snapped in the block. Ezi out to the rescue, dump the gauge temporarily and just use the donkey light till I can set it up differently. How much oil left? 1 litre!!!!!!!!!!!! |
06-08-2013, 05:00 PM | #378 | ||
Removed radiator, disconnect fuel lines from fuel pump, removed Harmonic Balancer Pulley, Loosing Harmonic Balancer Centre bolt, fitted Gilmer drive pulleys to Water Pump and Alternator...
1981 ZJ Fairlane [UNDER CONTRUCTION]
Build Thread http://www.fordforums.com.au/showthread.php?t=11401106 |
06-08-2013, 07:29 PM | #379 | ||
Oo\===/oO
Replaced valve springs!
06-08-2013, 07:41 PM | #380 | |||
I was surprised how much oil is in the converter itself, around 8ish litres I believe, so if you only change the 4 litres of oil in the tray it only gets approximately 1/3 of the oil changed. On topic, my front shocks arrived today and they are booked in for installation with the new SL springs and a wheel alignment tomorrow. |
06-08-2013, 09:48 PM | #381 | ||
::::::FALCON HELL::::::
Cleaned the "donk"
s1332.photobucket.com/user/Streetfighter500/media/image_zps94a108fe.jpg.html][/URL]
2012 FPV FG2 GS #410 428rwkw - KPM STREETFIGHTER - Intercooler - Twin throttle body - Bosch 900cc injectors - Boost pulley - Premium header back exhaust - Twin power filter - Oil breathers - Custom tune with SCTXCAL Tune box - Built ZF - CF Tailshaft - Harrop Ultimate f/r brakes slotted & cross drilled - 20x8.5 & 20x10 Streetfighter 3 piece wheels |
07-08-2013, 07:10 PM | #382 | ||
Finally finished the suspension on the taxi, Whiteline sway bars, 30mm front on hardest settings, 27mm rear on hardest settings, new shocks and springs, Kings SL front and SSL rear.
Hub to guard is 340mm at both ends, 105mm ground clearance on the lowest bit which is the exhaust. Alignment at front, toe +0.9, camber -1.5, castor +7.5 Alignment at rear, toe +1.0, camber -1.0. It is chalk and cheese how it handles now (well for a taxi anyway), excellent turn in, no understeer to really mention and with a nice controllable oversteer when pushed (traction control off). No more sledging and body rolling through corners for me. Happy days. |
09-08-2013, 02:33 PM | #383 | ||
New front shocks in the ute today...Monroe GT's. It handles like a new car now, It's brilliant.
My Ride... 2005 BA2 XR6 Magnet Ute. |
10-08-2013, 03:57 PM | #384 | ||
Whoa, this is heavy!
Added some fairlane woodgrain and chrome to the doors (fairlane door cars were too ratty) and ghia console button surround.
Also added my motorcraft numberplate cover on the back from my old fairlane. Not much, but its the little things that make it yours
Liquid Silver 2002 AU III Fairmont wagon Le Mans Red 1990 SA Capri Turbo
10-08-2013, 04:40 PM | #385 | ||
10-08-2013, 05:57 PM | #386 | ||
There's a very straight EL Saphire wagon at a wreckers just round the corner from me and for a couple of weekends, I've been visiting it and getting little bits off it for my wagon. Well I was there today and got all the door seals off it (I've been chasing a wind noise problem around the passenger front door) but what I am happy about getting - Instrument Cluster, Trip Computer and Climate Control switches from an EF Ghia - total cost $80.00.
I think I've got all the bits now to do the Climate control conversion - just need to find an EF Fairmont wagon so I can get the looms. Then I can do CC and rear power windows all at once.
476 EF XR6 Wagons - 198 were Manual 2010 Anniversary XR50 in Sunburst - 6spd Manual My Gallery Photos Here |
10-08-2013, 07:12 PM | #387 | ||
Started pulling the motor out...
10-08-2013, 07:20 PM | #388 | ||
BF XR8 Ute
Finally got my headlights pointing in the right direction,only taken me 2 weeks to sort out,pia to do as not a lot of room on BF to get hand and spanner in.
Cheers Geoff _____________ HIS 2006 BF MKII XR8 Ute,Shockwave Blue. HERS New One Coming Past Rides:- XD Panel Van,XE Panel van,XF Wagon,ED Wagon,BA Fairmont,LX Focus Greetings Earthlings. |
10-08-2013, 07:27 PM | #389 | ||
Lacking Imagination
replaced my Lower control arms because of this...
14-08-2013, 11:25 AM | #390 | ||
Ordered new suspension bushes for the BA. Superpro master kit for $600
