Old 24-08-2007, 05:22 PM   #31
20focus05
I wanna XR5
20focus05's Avatar
Well bit the bullet gone and ordered a full set also @ $121 each, bendix front pads $75 and ford rears @ $175ish that I was originally quoted $253 for them. rotors through motortraders and pads through ford.
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2007, 08:13 AM   #32
BlackLS
Nice work. You wont regret it.
Old 27-08-2007, 09:30 AM   #33
amlohac
amlohac's Avatar
i had slotted discs on my old focus, very much recommended. Plus they were cheaper than the OEM ford buckets of crap.
amlohac is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2007, 09:49 AM   #34
BlackLS
20focus05, you put yours in yet?
Old 27-08-2007, 03:24 PM   #35
20focus05
I wanna XR5
20focus05's Avatar
not yet getting them tue I hope. got to come from Sydney. then stick them in Sat just in time for fathers day lol
Old 27-08-2007, 03:26 PM   #36
20focus05
I wanna XR5
20focus05's Avatar
BTW ford quoted around $100 for standard rotors
Old 31-08-2007, 03:12 PM   #37
amlohac
amlohac's Avatar
was that the rotors for the zetec or the lower 1.8L model? different rotors on each i believe, was the case for the old focus.
Old 31-08-2007, 03:32 PM   #38
BlackLS
Driveline and brakes are the same CL to Ghia for the LS. Only Zetec has slightly different susp. XR5 is completly different.
I was quoted by Macarthur Ford Parts for 180-something if I remember correctly.
Old 31-08-2007, 04:32 PM   #39
20focus05
I wanna XR5
20focus05's Avatar
That quote I got was for the LS CL
Old 03-09-2007, 05:34 PM   #40
20focus05
I wanna XR5
20focus05's Avatar
Ha Ha found the front pads ford supplied are for the LR focus so I gues the quote for the rotors from them is up to too.
Lucky front pads are over 50%
those original rotors had been worn down a great deal.
The rear pads, the RH inter pad totally gone, outer 30%, LH side at about 30%
I have not usually seen rear pads wear out faster than the fronts? And rotors wear out just as fast as pads??
But the brakes feel good
Old 04-09-2007, 11:00 PM   #41
BlackLS
How many clicks does your handbrake go, perhaps its too tight. I found the rear inside pads gets worn faster than the outside as well, but the left side of my car wore out faster than the right side.
The stock rotors only have about 2-3 or so mm worth of wearing before they need replacing.
Old 04-09-2007, 11:23 PM   #42
smee323
Yes it is mine...
smee323's Avatar
If the rears are anything like that on the lasers, then there is an adjusting screw to wind the calipers in and out so you can fit the new pads.
Also best when fitting new pads and discs to bleed the system. Remember to move the pistons in and out to flush the bad from the caliper galleries.
I have an ST170, plus a GTR Familia rally car.
Will have to look at the ST to see if it is the same.
But Lucas pads are woeful on the standard discs.
smee323 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 11:38 PM   #43
BlackLS
Thanks for that.
No adjusting screw for the caliper anywhere on the LS :(
Nice familia, looks like fun, 4WD?
Old 05-09-2007, 07:23 AM   #44
melbzetec
Old enough to know better
melbzetec's Avatar
Smee, welcome to the Forums. And always good to welcome a rare ST170 owner! Lots of good people on here. Enjoy.
Where are you from?
Old 05-09-2007, 10:35 PM   #45
smee323
Yes it is mine...
smee323's Avatar
Originally Posted by BlackLS
Thanks for that.
Are you sure.
Sometimes there is a grommet covering the opening. You would need a fine flat head screwdriver to wind it in and out.
I am located around the Woodville area / Adelaide.
Old 05-09-2007, 10:59 PM   #46
BlackLS
Certain. The only sort of things coming out of the caliper are the
Piston
Brake line
Bleed nipple
Handbrake cable lever thingy.
I just read on the FFOC uk website and someone mentioned that the piston itself needs to be screwed (ie rotated) to go back in. Does this sound right?
Old 06-09-2007, 11:56 AM   #47
20focus05
I wanna XR5
20focus05's Avatar
Black my hand brake goes up quiet a way.
And the piston does screw in, with pressure at the same time.
I had no probs with them unlike you black but you have ABS?
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
Old 06-09-2007, 01:20 PM   #48
BlackLS
LOL I didn't know they screwed in. Good to see another slotted LS.
Old 09-09-2007, 06:57 PM   #49
simonr
Focus Rookie
simonr's Avatar
I ordered some for my LR should get em on Tuesday..
04' Panther Black Focus Zetec
Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters
simonr is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 08:25 PM   #50
photn
AFF Post NAZI
photn's Avatar
Let us know how it goes and how much they costed.
Old 10-09-2007, 05:30 PM   #51
simonr
Focus Rookie
simonr's Avatar
My Mechanic said the RRP were 200 each.. does that sound right?
Old 10-09-2007, 10:45 PM   #52
BlackLS
Tomorrow call up a Bursons etc and ask them. Most of the DBA i belive are the same price. (make sure you clarify 4 stud)
Old 13-09-2007, 12:09 PM   #53
20focus05
I wanna XR5
20focus05's Avatar
Simonr I got my rotors (for an LS) through MotorTraders the RRP was about $220+
So most mechanics will go on the RRP.
The price I go mine for ($110+)are about trade price as I used to deal with them in the past
Old 24-09-2007, 08:50 PM   #54
simonr
Focus Rookie
simonr's Avatar
I called bursons, and got the front 2 for $190 shipped..
Great Service, even though the guy struggled to believe my car was actually manufactured in germany, (after he tried to
compare known problimatic rotors in ba falcons to my focus)
My Mechanic was adamant that the price i got was way below his cost..
I got them today, im gonna call my mechanic in the morn and see if he can quickly put them on before i havta goto work 2mrw morning
Old 24-09-2007, 11:42 PM   #55
BlackLS
yum
F me dead you got a good price!
2005 LS Focus LX
250,000kms.
Old 25-09-2007, 04:47 PM   #56
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
uhh, could be mistaken, but the foci imported to Aust with the exception of the ST 170 and the XR5 were all built in South Africa.
By any means he should be nailed upside down by his scrotum to a wall for making any comparison to a falcon. Heh.
Thinking of doing this in the future to mine, there's a bursons within walking distance of my place now so i might give em a go.
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2007, 05:44 PM   #57
photn
AFF Post NAZI
photn's Avatar
Not quite true mate. ALL LR's where built in Germany except the Sedan which was built in Spain. Only the New LS and LT's where built and are built in SA apart from the XR5T
Old 25-09-2007, 06:16 PM   #58
melbzetec
melbzetec's Avatar
There is an early thread here somewhere(I think Zetec posted it) that decodes your VIN. One of the letter/number positions tells you which factory/country your car was built in.
TJ, I'd lay money yours was built in Saarlouis, Germany
Old 25-09-2007, 06:59 PM   #59
simonr
Focus Rookie
simonr's Avatar
haha exactly..
thats why its the EURO ford club.. the proper EUROfords are actually built in Europe :P
Old 26-09-2007, 08:01 PM   #60
Tj-zetec
Tj-zetec's Avatar
Told you i could be wrong. I'm a dope like that. Can't remember where i heard the SA thing.
oh well, it does make me feel a little better knowing my car is actually european, not pseudo euro.
