Old 07-06-2013, 11:13 PM   #31
marcosanga
Default Re: Clicking and Clunking noises
Ive had similar noises on my 2007 TDI focus.
The clicking noise was rectified under warranty, i think it was the bearings that support the front drive shafts, in the gearbox and externally all done under warranty.
The second noise i still have is a clunking sound just after letting the clutch out that mostly only happens in 2nd.
Had it into a few dealers over the years and of course they couldn't fault it, ive just learnt to live with it and it seems to have subsided a lil over the years.
And today found the clutch pedal stuck half way down on returning to the car, popped it back up and it seems to work ok....?
2005 BA Mk2 XR8 6SP in Velocity Blue, Full Premium Pack
marcosanga is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2015, 03:55 PM   #32
disco stu III
what?
got the same. spline has no play, nor the joint. looks like the outer bearings of trans/diff out got play. anyone tried this first?
disco stu III is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2015, 02:40 PM   #33
disco stu III
what?
just pulled the shaft out. inner joint is flogged, birfield or whatever's in there. nothing to do with diff bearings. guy at cv shop reckons the diesel is even worse for this than the xr5. a lot of play for something with only 50,000 odd km on it.
Old 21-02-2015, 12:31 PM   #34
05_ENFORCER
05_ENFORCER's Avatar
Just an update on this thread mine for others who have a Focus and it "clicks" when taking off in a straight line.
Got the clicking noise fixed yesterday by Ford under warranty, it took a bit of coaxing but they agreed it was a warranty item.
If not I was going to flick out the Ford ETIS TSB 63/2012 for them to read.
(Clicking when taking of in first or when reversing)
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2015, 11:07 AM   #35
mik
mik's Avatar
Did it have many k's on it when the noise started ?
Old 26-10-2015, 11:04 PM   #36
theBlake
theBlake's Avatar
Could you also describe this as a rattle and it wont occur if you give it plenty of Revs as you start off?
Its been happening to my LS Focus for 9 years and it ****** me off no end.
2007 BFII RTV Ute Auto
theBlake is offline   Reply With Quote Multi-Quote with this Post
