02-05-2008, 09:23 AM | #31 | |||
02-05-2008, 09:31 AM | #32 | ||
The Origional, The Best
Ok, so for a nub from the territory who is going to live in VIC for a few months come June, and is driving down his AU, complete with front Bar and driving lights. Can someone tell me weather these driving lights mounted in the bar are illegal to use in anything but bad weather? or are we talking the big bastards that people mount on nudge bars?
Current Mods 2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts Future Mods Lowerage on KingSprings Lows | Engine...Period | Sounds System I Use And Recommend F1 Tyres And Wheels On The Gold Coast Proud Supporter of Beat The Heat (NT)
02-05-2008, 11:00 AM | #33 | ||
Maybe just like how Volvo park lights come on with the ignition, to warn other drivers that a Volvo is approaching,the fog lights warn that a is on the road (when used when not required due to weather conditions that is)
02-05-2008, 11:14 AM | #34 | ||
Performance moderator
Modified fog lights should be looked at and defected, same with rear fog lights..
If there's 50 watt light in them and say ??? 20 watt in rear light I cannot see an issue ?? If the lense is clear and smooth its a driving / spot light...Esp with over 50 watt globes.. This where the confusion is.. I have had some people complain about the fog lights on my car flashing in there eyes.. There is NO way the fog lights on my Rex would get into any one's eyes .. I think in SOME cases people just want to WINGE... Envious they havn't got them ???..
02-05-2008, 11:53 AM | #35 | |||
Guzzler
AUI XR8 - 250kw Herrod enhanced, 18's, lowered 1999 Mustang Cobra, Mick Webb tweaked, 18's, 1971 XYGT (replica) My first love. |
02-05-2008, 01:16 PM | #36 | ||
What if they are wired up to your high beam?
02-05-2008, 01:46 PM | #37 | |||
[SIGPIC][/SIGPIC]
02-05-2008, 02:33 PM | #38 | ||
It's all in the curves
Guys to clarify a couple of points that apply here:
There is a very good reason why it is illegal in most sensible countries including ours to drive around with your foggies on unless foggy. They are designed to produce light under the fog layer in bad driving conditions when main beam just bounces back at you. So they are still forward projecting beams of reasonable (often 50 ish w) intensity. People who say "but they are only the same as my dipped headlights" miss the point - dipped beams are specifcally designed to throw light down and to the left, and hence not glare oncoming traffic. Foggies send light straight ahead, even if they are mounted low. Older designs happen to be dull enough not to be an issue, and fine, but why use them anyway? If you want to be seen (and it is proven to be safer), use dipped beam. If that is blinding people more than your foggies, get your dipped beam adjusted. And folk above are correct: driving lights = additional main beam lamps (the ones that come on in addition to the main beam lamps in Falcons actually count as driving lamps even though part of the "normal" headlamp). After market pencil beams that wire to the driving lamps are also driving lights. Some cars have side lights mounted in the bumper bar seperate to the main lamps, but if they are of low 20w or so rating and of spread beam they are just side lights. If you have lights like this that must be on with dipped beam they are likely to be side lights. Fog lamps can be turned on without main beam soley so you avoid rebound off the fog, not so as to let you point them at people. Rear fog lights (not mandatory in Oz but they are in the UK and other places), again are only for VERY low visibility to stop people on fast roads driving into the back of you. They should never be on once another vehicle is close behind, and never in good weather. This is because they are exactly like brake lights (indeed many euro cars have a pair next to the brake lights, and only the absence of a third high-level one give up the fact they are fog lights). NEITHER front or rear fogs should be used in rain (unless it's so torrential you think someone might crash into you at 10k/hr), as they cause glare off wet glass windscreens. Still, last thought for the weekend - none of it compares to muppets with badly adjusted main lights or bulbs out. We're all saints compared to them! Have a good one. Andy
EB V8 Wagon straight gas AU manual box, billet shifter. Alloy gas tank from PPI : 5.0L with AFR 165s, Random cam, Pacemakers with full twin system Mallory programmable distributor ign Weiand x-cellerator manifold and EFI adaptor 75mm TB No MAF Alfa seats Shortened alloy shaft Whiteline bars F+R (30/22) Slotted rotors + all new bushes/joints up front Build thread here |
02-05-2008, 03:03 PM | #39 | ||
Rob
as far as i'm concerned, fog lights are yellow. any other light is a driving light and the law does not apply.
02-05-2008, 03:13 PM | #40 | ||
Extreme Machine
hang on,
driving lights are different to fog lights |
02-05-2008, 03:52 PM | #41 | ||
Regular Schmuck
This old chestnut again.
Certain fog lights dazzle me when driving (even during the day) and a number of times on Heathcote Rd (where it's single lane 100kph) I've been dazzled by fog lights to the point where it impared my vision significantly. VX Commodores are the worst but I have been dazzled by a number of B series Fords. I don't know what it is about them but it makes my vision white and glassy. So if you want to pull out the 'it's safer' line and keep in mind that some drivers (like myself) get impaired vision from certain fog lights while your closing speed with me is ~200kph, then you have a skewed version of safe. The other argument is 'I'm just jealous of them'. I have them on my BA and it's the only switch in the entire car I've never touched. If you want to be seen better during the day, put your headlights on. Leave the fog lights for fog. |
02-05-2008, 04:03 PM | #42 | ||||
02-05-2008, 06:08 PM | #43 | |||||||||||
Mot Adv-NSW
If anything, the rear fog lamp should be a mandatory feature - for those unhappy times when they might be needed. Cheap insurance! Indeed, it is the only 'mandatory' fog-light system in the world; EU. Front fogs are and will always be optional, everywhere. Quote:
1. Front fog lamps are complianced at 12v55watts. 2. Front fog lamps are either white-optic or selective yellow in colour. 99% of the new car market use white-optic version. 3. Rear fog lamps are complianced and supplied with P21watt bulbs 4. Momentary glare might be caused by a loose lamp/bulb/housing or by hitting a bump in the road, when approaching traffic over a crest etc. Quote:
Front fog lamps can aid very well a drivers vision when under moderate to heavy rain conditions. It is what is taught to learners on the Continent of Europe and is also suggested so by Hella, in their manufacturers handbook. Quote:
The VIC rule change, results from a changed ARR217. ALL STATES and the NT and ACT will now have the same prohibition. WA and NSW have always maintained such a prohibition in regulations seperate to the ARR's. Mind you, your chances of being booked? Well, in NSW our HWP cars rest at stations.
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf Last edited by Keepleft; 02-05-2008 at 06:19 PM. |
02-05-2008, 06:20 PM | #44 | ||
Arent they called driving lamps? i use them quite often and never had a problem .
Mark
BA 03XR6T, 968's, SS CAI, PWR Cooler,Nizpro valve springs, BMC,Typhoon 18's, Brembos, 3 1/2' cat back Future mods Blisten shocks and King springs.391rwhp |
02-05-2008, 06:21 PM | #45 | ||||
Mot Adv-NSW
A driving light must not operate when the cars headlights are on low-beam or with the cars parkers (sidelights). An actual compliant driving lamp, bears totally different photometrics and beam characteristics to those of front fog lights, but colouring of a front fog lamp or driving lamp can be 'white-optic', that is the same! Here, on a driving lamps lens,- near its 'E Mark'; will be the designation "HR", the letter "R" tells police the lamp is a complianced driving lamp! Last edited by Keepleft; 02-05-2008 at 06:33 PM. |
02-05-2008, 06:41 PM | #46 | ||
Well I use them whenever i feel like it , driven past coppers with them on and no such problems. Probably how you act with them on I'd say as to whether you get pulled over or not.
02-05-2008, 06:47 PM | #47 | |||
Mot Adv-NSW
The law stands, and whether or not it is enforced is a matter for each jurisdictions indvidual HWP and police. (The new rule change brings AUS in line with the rest of the world btw, with regards this subject). That said in behavioural terms; why should I not, say, ~ drive in the right-lane of freeways at the speed-limit cause 'I feel like it', why should I use my indicators if I don't want too?? Etc etc..... Perhaps you should start a new thread vis; "What road rules do you deliberately dis-obey, generally, and why??".
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf Last edited by Keepleft; 02-05-2008 at 06:54 PM. |
02-05-2008, 06:56 PM | #48 | ||
Woo hoo ... the fog light thread ... AGAIN.
Read the road roads ... it is ALL in there. Keepleft has pointed out pretty much the main points ... he knows the rules here and abroad (as it is part of his line of work) ... no use arguing with him about it either. I can't believe the amount of posts in here with people stating stuff that isn't even correct. Thank goodness someone put the correct information in here ... I just didn't have the time to write it all in while at work.
02-05-2008, 07:43 PM | #49 | ||
Nikon
IMHO every commo cars should be classed illegal because some anus allow these to have a brighter than average bulb causing the Policy maker to blanket cane everyone.
Point should be taken as too line up a falcon and commo and a see and look approach is needed |
02-05-2008, 07:57 PM | #50 | ||
The one and only
Before this thread get's locked.
A) It should have always been illegal B) You are not Mark Scaif just because you have fog lights C) this with current hi serires cars will still complain that the lights do not distract.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
03-05-2008, 07:49 AM | #51 | ||
HSV - I just ate one!
what i'd really love to know is, wtf is the point of driving around with your foglights on if it isnt foggy? one of the few perks of my job is that i get to drive anything on the yard home, which means i've driven XR's, SS commodores, landcruisers, prado's and pajero's with foglights, and with ONLY the foglights on, i'm if i can see anything properly on the road further than 15 feet in front of me...... and thats in CLEAR weather, i wouldnt drive with only foglights on at night, so i turn them off and use my low beams
makes me ask..... "if the foglights dont serve any functional purpose in clear weather, why turn them on??"
03-05-2008, 12:25 PM | #52 | |||
Because as we all know its safer to drive with lights ON.. It works for bike riders and sure does on cars. Some people have issues seeing certain colours.. But they all see lights.. I was a passanger in a car when the driver went straight through a railway crossing with RED lights flashing...I yelled at him !! Are you going to STOP!! I found out he was colour blind and couldn't see the lights flashing... We don't have cars fitted with PROPER day lights so the fog lights do the job.. The problem is people change the globes and lense in them!!
03-05-2008, 12:32 PM | #53 | ||
Fog lights have been banned unless there is fog in WA for ages.. Mostly I think because people were using them right next to their numberplates to blind speed cameras.
Only foglights that really annoy me are the rear red ones on excels.. Although I do think people look stupid with all their lights on during the day, why not just run your normal lights, why run everything? |
03-05-2008, 04:57 PM | #54 | |||
Regular Schmuck
Since when did bikes come fitted with fog lights? |
04-05-2008, 02:17 AM | #55 | ||
I cant believe it took so long for KEEPLEFT to wade in on this thread. Nearly 22hrs KL, you must be on holidays. And I'm with RODp, although i dont think i actually know where the switch is on my XR.
igodabigblackshinycar and I relented and allowed a BMW into the garage. |
04-05-2008, 11:45 AM | #56 | |||
Clevo Mafia Inc.
04-05-2008, 01:42 PM | #57 | |||
Regular Schmuck
04-05-2008, 04:19 PM | #58 | ||
well yesterday while police where searchin thru my ute they told me it depends on the cop you get and what mood he is in if u get a fine or even get pulled over. i havnt had a problem so far
04-05-2008, 09:38 PM | #59 | |||
Mot Adv-NSW
Can't find the XR's fog lamp switch? See this post, note the ISO symbols:- http://www.fordforums.com.au/showpos...78&postcount=4 Been away, just had a quick run up to Tamworth, observing RTA's new speed cameras on the New England Highway located in 60km/h zones at those smaller towns. Speed between towns by a clear majority in the 100km/h zones varied between 110-130km/h. A Saturday afternoon drive left me thinking (//) might best be applied once again, we'll see. Noted Tamworth has changed much in the last 5 or so years since I last dropped in. Usually, I drive around the place!
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf |
04-05-2008, 11:37 PM | #60 | |||
What's green is gold
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
